Results 1 to 10 of 15
Thread: '87 Ford Crown Victoria?
    Sep 2006
    I Am thinking of buying an '86 Ford Crown Victoria, and was wondering if anyone can tell me if I'll have any issues building a carputer regaurding electrical.. Fabrication seems like it would be fantastic in this car, but I'm wondering if the lictrical is sub par? It's old, yeah, but it has power windows, seats, locks, everything like that..
    Sep 2006
    Thanks for moving topic, my appologies on mis-location in the first place.
    Jan 2005
    I'm no expert on the subject, but outside a strong alternator and fresh battery I don't think there is much to worry about. Most of the wires you will be running will be your own.
    FLAC john1701's Avatar
    Mar 2004
    Fort Myers, Fl
    01 vic here. no problems running dual batteries on stock 130amp alternator. doing it for almost 2 years. stock alt still going.
    CAR:2001 Ford Crown Victoria
    PC: Acer EEE 900HA with Win7 with CF 2.0.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Screen:Xenarc 700TSV
    The Florida Meets Thread
    Sep 2006
    John1701: Could you mspaint me a diagram of that? are they series or parallel? I know electronics, but I'm completely new to automotive. I'll have to go see how it all works out.. Hopefully the rating is on my alternator.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by XHorntail View Post
    I had an '86 Crown Victoria (that was my favorite car of all time, even to this day anyways, back your [future] installation...
    from what I can remember there was a ton of space behind the dash in that car. years ago when I had mine, I had installed a uniden Grant XL CB radio in the dash (that thing was huge, believe me). you will have plenty of room to work with in that car.
    as far as the electrical is concerned, it's not much different from any car made today. the same rule-of-thumb applies to both old and new cars:
    • only use the factory power wiring for signal lines (to switch relays).
    • run your own power cable(s) directly to the battery. the wire should be thick enough to handle more power than you need from it, and make sure you fuse it at the battery.
    • if you will be using an amplifier to drive your speakers, then you should run new wires to your speakers as well)
    the bottom line is, it doesn't really matter what conditon the factory wiring is in because you should be running your own wires to power everything anyways
    as for your alternator and battery, the car is 21 years old, so who knows how old the alternator and battery is. it's anybody's guess how long each one will last (unless they were replaced recently). if they're old and you put a load on them (carputer, amplifier, etc.) then you may have to replace one of both of them in the near future, but the good news is that they are cheap to buy and easy to replace
    oh, and BTW, unless you plan on using the carputer for long periods of time when the engine is off then there is no need for a second battery.
    good luck with your future install
    Mar 2004
    Fort Myers, Fl
    i have the batteries in parallel. positive to positive connection. Using two optima red tops. Just ran 8 gauge wire with a 80 amp fuse on both ends from the front battery to the trunk. The rating (amperage) of your alt, you can find out at any auto parts store.
    Like ComputerGeek said, there is ALOT of space in the dash. since the CV's really have not changed over the years. On mine I can stick 4 epias with PS and HD just in the dash without any cutting or modding. Under the steering wheel there is a cover. remove that and you can put 3 pc's there. remove the radio and one can fit there. behind the hvac controls, you could squeeze two more there. Also if you remove the glovebox, one epia can fit behind it. but there it would really be a tight fit.
    oh by the way there is the grand canyon of a trunk, could put one there.....
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Mar 2004
    Fort Myers, Fl
    also under the ashtray you can stick a full mobo.
    Memory:1G
    Drives:160gig
    WI-FI:Cingular
    GPS:IG2k9
    Jul 2007
    Decatur, IL
    I have same car damn near, I have an '81. If you need any help with this car at all, not regarding carputer specific questions, I can help you. I have had my '81 apart so many times. These cars were very much the same from 1979-1991.
    Sep 2006
    I'm glad there's so many people on these forums to help me out, and in such a positive way. There certainly IS a ton of space to put things! Since the "laminated wood" panneling simply screws on, I think I'll replace it with a kydex mold ad see how that looks. Kydex will hold up a lot better, and it'll be easy to fab i think.. Any other material suggestions? Oh, and my alternator is really low.. like 106 amp.. Should I get a new one? how much do they run? and do i need a certain form factor?
  1. 2001 Ford Crown Victoria Police Interceptor
    By TMDJ in forum Show off your project
    Last Post: 10-05-2007, 08:25 PM
  2. FS Ford OEM stereo AUX input connector unit
    By Dave One in forum Classified Archive
    Last Post: 08-17-2006, 02:49 AM
  3. 1997 Ford Crown Victoria Stealth cop car project
    By xdjxklusivex in forum Worklogs
    Last Post: 08-14-2006, 08:23 PM
  4. 1997 Ford Crown Victoria
    Last Post: 08-11-2006, 12:51 AM
  5. Question...Jaguar, Daimler, Ford...
    By RoyN in forum Off Topic
    Last Post: 12-30-2005, 04:25 PM
