Results 1 to 7 of 7
Thread: To Solder or not to Solder?
    Jun 2007
    I just baught the MacPac Cable now when using the loose colored wires do you have to strip the wire ends and solder them together or can I just twist them together and wrap electric tape around it???
    Newbie to wire connections please bare with me, couldnt find anything in the search...
    Elsewhere
    Twist and tape is good for testing ONLY.
    You want a more secure electrical connection. Either solder the wires or use good butt connectors (aka crimp connectors).
    How about the Wiki?
    Jun 2007
    Quote Originally Posted by DarquePervert View Post
    I found a couple at radio shack...will these do: http://www.radioshack.com/product/in...entPage=family
    RadioShack.com - Cables, Parts & Connectors: Connectors & connectivity: Crimp connectors & terminals: Crimp-On Snap Connectors (10-Pack)
    Jun 2007
    can you lead me to decent connectors
    _
    Mar 2004
    Little Elm, Texas
    Solder. ALWAYS solder unless it needs to be removed easily.
    Solder is the best conductor. Crimps come undone too easily when crimped incorrectly.
    Soldering is VERY easy and can be taught in less than 5 minutes...at least that's how long it took me to learn it...and if I can learn it in 5 minutes...
    There is a technique that should be used when crimping, but I don't even want to go into that as you should solder.
    Jan Bennett
    _
    Mar 2004
    Little Elm, Texas
    Perhaps this FAQ will help some:
    http://www.mp3car.com/vbulletin/faq-...n-methods.html
    I HIGHLY suggest reading through it.
    Jan Bennett
    Jun 2007
    where can I buy heatshrink wrap and rosincore solder?
    nevermind ace hardware has it, thanks for the help people.
  1. Laptop remote switch - where to solder exactly ?
    By frontliner in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 02-14-2007, 09:18 PM
  2. How do they get the rosin inside the solder?
    By rotarypower101 in forum Off Topic
    Last Post: 01-28-2007, 04:57 AM
  3. HUs with detachable face for remote mounting
    By RedGTiVR6 in forum Car Audio
    Last Post: 08-31-2006, 01:49 PM
  4. learned how to solder!
    By Stillalive2029 in forum Off Topic
    Last Post: 06-14-2006, 12:23 PM
  5. Broken antenna
    By sfay93 in forum Wireless Communications
    Last Post: 04-15-2004, 03:41 PM
