Results 1 to 2 of 2
Thread: 04 accord with navi problems
    Jul 2007
    I have an 04' accord with a navi system, and recently the navi just sits there saying "please check your disc" regardless of a disc being in there or not. When a disc is in there though and you start the car it will say now downloading software, then right back to please check your disc. Now personally i was thinking, i would prefer to just go to a carputer, but the navigation system controls the clock and quite a bit of the ac controls (direction of airflow, amount of air blowing). So i was curious about two things.
    1) is there a way to get those controls through some kind of front end?
    2) is there a way to run the carputer through the stock navi screen?
    I would appriciate any help. or if you know what my problem is with the car that would be cool to, although after running through the tech manual for my car im pretty sure the problem is the dvd-rom that runs the navigation.
    -Noel
    Mar 2006
    Colorado, but Canadian!
    1.) The controls need a piece of hardware to control it. Something like the Fusion Brain. You need something to go from the virtual world to the physical world, which an USB I/O Board would do.
    2.) Well... ish. There have been a few people successful with integrating their OEM screens. Things you will need to overcome is the touch overlay not being USB and the video input not being VGA usually. There was an instance where an OEM screen was a 640x480 and he got VGA into it but with lots of research and time. Usually they are composite monitors (like a dvd screen). That means with a computer it will be blurry. Useable but blurry/fuzzy. For the touchscreen, if your OEM TS overlay is a 4 wire, then you can plug that into a USB TS controller (~$50) and then the presses will work like a mouse with your PC.
    The particular case I keep talking about the guy actually used a bunch of relays to share the screen with the stock system and the CarPC. I suggest you try to do that first IF you are intent on keeping your OEM screen and most stock look. That way you can "switch" between the OEM stuff (including the hvac controls) and the CarPC. You need to have a switch that trips relays for both the touchscreen and the video input, or else your presses wouldnt coorespond to what was on the screen at the time.
    Good luck.
    1.9in x 2.9in -- 47mm x 73mm
  1. Replies: 33
    Last Post: 03-28-2008, 03:18 PM
  2. Replies: 4
    Last Post: 12-27-2006, 04:22 PM
  3. 04 accord radio problem
    By DADAMS09 in forum Car Audio
    Last Post: 12-11-2006, 07:06 PM
  4. 2004 Accord radio problems... please help!!!
    Last Post: 12-02-2006, 12:05 PM
  5. Hard drive shock problems.
    By Mikesz in forum General Hardware Discussion
    Last Post: 03-21-2005, 04:37 PM
