Results 1 to 4 of 4
Thread: Sony Screen Yes or No?
    Mar 2007
    I've got a 6.5" Widescreen Sony monitor that I pretty much got for free.
    Will that work as a monitor?
    * Display Type: TFT-LCD Active Matrix
    * Picture Segment: 280,800 (1200x234) pixels
    * Picture Size (mm/inch): 124x73, 5x2-7/8
    * Display Size (inch): 6.5
    * Color System: PAL, NTSC
    * Video Inputs: 2
    * Headphone Output: IR
    * Aspect Ratio: 16:9
    * Video Output: 75 ohms, 1V p-p
    * Weight (lb/oz): 0/11
    * Operating Temperature: 41-113
    * Current Drain: 600mA
    * Power Requirments: 12 VDC
    * Connection box: XA-113
    * Depth (mm/inch): / 1-1/8
    * Height (mm/inch): / 3-7/8
    * Width (mm/inch): / 6-3/8
    Elsewhere
    If you can get your PC video to a composite signal, then yes.
    Mind you, the display will NOT be crystal-clear, particularly with text and the display will likely be fuzzy and/or grainy. Your display resolution will also be limited.
    How about the Wiki?
    Mar 2007
    I'm going to be gutting and using a Winbook laptop which has, S-Video and composite outs.
    Mar 2006
    Colorado, but Canadian!
    Well with a frontend and perhaps a 6.5" touch overlay, you could make it useable. 6.5" is actually the perfect double din size. Meaning all those aftermarket units with touchscreens will use the correct overlay. So if you find a broken one on eBay or an overlay for one, justmake sure you see 4 or 5 wires coming off of it, and you can buy a USB controller for it.
    And free is always the best price.
    1.9in x 2.9in -- 47mm x 73mm
