Most DC-DC PSU's have a remote amp on wire with a delay so that it prevents thumping when the audio drivers load.
hi guys, i am just wondering. When i install my carputer, the remote wires for my amps, should i connect them to my ignition wire? or to something else? reason i ask is because im used to the radio supplying that wire so now im unsure which way to connect it. Thanks!!
1.9in x 2.9in -- 47mm x 73mm
which PSU are you using?
Jan Bennett
Do you have the owners manual?
It will show you in there how to hook up the remote turn on wire.
Jan Bennett
a google search only turned up this thread: Ignition Switch Details?
And a russian thread on PCCar.ru
Apaprently it's a 90 watt PSU from OPUS but I cannot find that part number on their web site.
Jan Bennett
Use the serial cable mod for your remote for the amps.
where did you get the PSU from?
Jan Bennett
