The M2 won't work. IT's for an ATX-compatible motherboard, which this HP unit is not.
The package comes with a car cigarette lighter plug that is connected to a "power brick".
You can use that and get a shutdown controller, as one option.
Check the power brick for an output voltage. Depending on that, you may be able to use a Carnetix power supply that has a built in shutdown controller.
LinkBack URL
About LinkBacks
