Okay I am really new at this but I have purchased a touchscreen monitor (very cool I must say). but I have an extra computer in a regular computer case (laydown tower) can I use it? if so how do I hook the power up to it, it is a regular 110V power cord. Any help here would be very appreicated. I cant afford to start from scratch so if i could use this puter that would be pimp.... thanks
1.9in x 2.9in -- 47mm x 73mm
okay so i bought the CarNetix CNX-P2140 V1.1 Dual Output Regulator but i am a little confused on the wiring so do i need to replace my powersupply in the case with a different one or can i just open up the power supply and find the main power or is it more complicating than that?
I saw in another post that someone had the same powersupply that i just got but he had a mac (yuck). and the wires were already comming out of the case ready to be hooked up. any other help would be appreciated. Also I downloaded the manual for the CarNetix Powersupply and the manual is version 1.2 but the box and i have here is version 1.1 is there any diffence that i should be awear of? thanks everyone i really do appreciate all the help!
If you couldn't afford to start from scratch why didn't you research that PSU before you purchased it?
I would recomend starting here:
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=2
Then moving onto here:
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=3
and then here:
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=6
Then to here:
http://www.mp3car.com/vbulletin/advf...iew&advfaqid=5
Good luck!
Jan Bennett
Okay now I see where i made my mistake I ordered the worng powersupply. I ment to get the OPUS 250W powersupply but did it in a hurry and screwed up. thanks everyone for the help.
