Results 1 to 4 of 4
Thread: Power supply
    May 2007
    Power supply
    This is my first post, great site BTW.
    I have a mini-itx sp-13000 board and case with dc-dc power converter that takes a 12v5a power adapter. Ideally I would like to be able to use it as a GPS in a rental vehicle for a trip. Any info on whether this is doable using a cigarette adapter, I realize most of the ones I have seen are cheap 2 amp ones, so maybe I am out of luck. It would only be used for 2 or 3 days.
    Mar 2006
    Colorado, but Canadian!
    well if it is a rental car, then sure. Make sure to get the rental insurance. If you torch the car, you get your money back.
    5A is ok probably, but still you never know what else they have connected in there. Usually the fuse is only 10A-15A.
    1.9in x 2.9in -- 47mm x 73mm
    Elsewhere
    It might work.
    If the DCDC power converter accepts unregulated 12v power, then it would likely be OK. The key there is unregulated power, though. If it requires regulated power, you'd neeed to find a way to regulate the cars 12v power (which actually fluctuates from as low as 8v to as high as 15v depending on many factors) for the PSU in that miniPC.
    Quote Originally Posted by 2k1Toaster View Post
    Good thinking Toaster!
    Be sure to bring marshmallows to roast in case something goes horribly wrong and the car burns.
    How about the Wiki?
    May 2007
    Thanks guys, maybe I'll pack a few wienies and a fire extinguisher, I can always ask the nice fireman for directions.
  1. My low cost, easy to build power supply...
    By SkinnyBoy in forum Power Supplies
    Last Post: 09-27-2006, 07:10 PM
  2. REVIEW::220 Watt DC-DC Power Supply: DSATX
    By seabeggar69 in forum Power Supplies
    Last Post: 03-20-2006, 05:53 PM
  3. Shuttle G5 1100h and Opus Power Supply
    By Caelric in forum Power Supplies
    Last Post: 11-16-2005, 05:13 PM
  4. DC-DC Car Power for Mac Mini
    By MikeH in forum MacCar
    Last Post: 02-19-2005, 01:13 PM
  5. Power Supply Options?
    By Optikal in forum Power Supplies
    Last Post: 06-26-2004, 06:46 AM
