Results 1 to 5 of 5
Thread: engine noise through speakers
    Sep 2007
    I just installed an amp to my front speakers.Its not cheap,its an MTX.Now i have engine noise in my speakers.The power wire is on the drivers side and the speaker wires on the passenger side.But they meet up in the back and come through in the same spot.Could that be the problem?I'd appreciate any help.
    Low Bitrate kazzxtrismus's Avatar
    May 2007
    keep all wire seperate.
    ground close to chassis, and often...or to battery.
    clean all alternator connections
    solder all joints
    use large gage wire dependant on wattage
    if its just for fronts mount the amp under a seat.
    this will all help...there are noise supressors too
    06 Altima..SER front bumper.
    CAR PC.....soon to be true!!
    Oshawa Canada!!
    Sep 2007
    Thanks for the advice.
    I'll mount the amp under the passenger seat.
    Jan 2007
    East Central FLA
    It has been my experience that power and speaker wires seldom are the cause of engine noise (not that it can't be). I would check the routing of the RCA cables from the source to the amp - make sure they aren't routed near OEM wire bundles as there are many signal circuits in the car's electronics that can create audio noise. But first and foremost is a ground loop - usually caused by lack of a central ground (or insufficient ground). To fix that, the source unit and amp (and anything else in the signal chain) all share a common ground point.
    Sep 2007
    My cd player only has one RCA output.MY brother told me how i can hook it up so its kinda rigged,but it works.Also,the speakers with the engine noise start to smell if i play it loud for a minute.I'm thinking the speakers can't handle the power of the amp.
  1. Replies: 35
    Last Post: 08-04-2009, 10:29 PM
  2. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  3. inverter makes noise out of speakers
    By snoop in forum Power Supplies
    Last Post: 01-21-2005, 06:28 PM
  4. VGA Cable causing engine noise
    By sq_geek in forum Car Audio
    Last Post: 12-28-2004, 12:47 PM
  5. Engine whirl through speakers.
    By ppgt94 in forum General Hardware Discussion
    Last Post: 09-01-2004, 03:27 PM
