you're most likely safe... the 7" screen that everyone uses on these forums draw about 10 or 12 watts... a running laptop is likely to use around 75watts - when it gets hotter you will use MORE power because the fans eat up the juice.
Keep in mind that every component you add will require more power, so figure 5 watts per USB device, don't know how you intend to surf, but wifi is a power hog...
you didn't say what the connection between the screen and laptop was going to be, but expect pretty low resolution if you are using anything but VGA. Most of those screens are 234pixels tall, so text will be pretty illegible. Don't believe the 1440 pixels of width they advertise, because that is just counting every pixel - but technically the red, green and blue are grouped to count as one... so 1440/3 = 480. Plenty of res for a movie, but a bit weak for reading text.
LinkBack URL
About LinkBacks
