The live wire should get 12v all the time.
The ACC should get 0v when the key is off ans 12v when the key is on.
Have you measured the voltage on these lines with key on and key off?
Also, have you checked all your fuses? most amps don't have an on/off switch, just a remote wire that senses ignition state, much the same as your M2ATX PSU.
LinkBack URL
About LinkBacks
