Results 1 to 6 of 6
Thread: So many devices, so few USB ports
    Sep 2007
    Corona, Ca.
    I am in the process of laying out the wiring for my car PC. There are so many USB devices I would like to incorporate that a 4 port hub and 4 ports on the PC are not enough. I will need a second hub.
    These are my questions:
    Is there any difference/advantage in plugging into the ports directly on the PC instead of a hub?
    Can a second hub be plugged into the first hub without problems?
    I will be using the following USB devices:
    DVD-RW, GPS, XM satelite adapter, 4 port hub, wireless keyboard, bluetooth phone, OBDII, touchscreen, USB dash board open port.
    Getting quality goods and service is like buying oats. If you would like clean, fresh oats you must pay a fair price. If you would like oats that have already been through the horse, those are a little cheaper.
    Elsewhere
    Why not get a single 8-port hub?
    Also, check your motherboard. There may be headers for additional USB ports.
    How about the Wiki?
    Sep 2007
    Corona, Ca.
    I have no problem using a larger hub. What I whant to know is, for example, would the DVD drive work just as well connected to a hub with several other devices as it would connected straight to the mother board. I don't know how the bus works. My thought is that the one line coming from the hub is now carrying information from several devices on that one line coming from the hub. Is that increased traffic going to slow down all the devices? Would there be a problem watching a DVD with other devices running on the same hub?
    As far as checking for additional usb ports on the motherboard I'll have to check the manual. I bought the beginner car computer from MP3Store. Mini ITX mother board? Maybe you know if that has extra usb ports.
    Low Bitrate Pint's Avatar
    Aug 2007
    Melbourne
    From what I can see the begginner's kit comes with a voom PC - Jetway VIA C7 2.0GHz CN700 Mini-ITX Motherboard???. I have one of these and the motherboard does have headers for additional usb ports.
    Have you considered running 2 x 4 port hubs of the back ports and distributing the devices so as not to have 2 high traffic devices on the same hub.
    Alternativly the VooM PC has a slot for an internal DVD drive. It gets a bit cramped ( I shortened the ribbon cable to increase airflow), but there is room.
    Things to do
    • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
    Sep 2007
    Corona, Ca.
    Quote Originally Posted by Pint View Post
    I had planned to run 2 - 4 port hubs as I already have one of them.
    The PC will be mounted in an area not accessible while driving, so I had the DVD drive external.
    Found some good info here: http://www.tomshardware.com/2003/09/...ogy/index.html
    It's not exactly what I was looking for, but gave me some insight.
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    I would run a powered hub...and try to find one that uses +5...all the ones I have seen use +6...don't know how well that would do plugged into a computer power supply.
  1. USB devices help!
    By Focal in forum Newbie
    Last Post: 04-25-2007, 05:46 PM
  2. Extra (hidden) USB ports on Laptop?
    By Nerd2 in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 03-12-2007, 05:07 AM
  3. Installing a USB Hub up-front? Read this...
    By hd54321 in forum General Hardware Discussion
    Last Post: 02-09-2007, 12:49 PM
  4. Adding USB ports to Via mobo's
    By Slightly_Stoopi in forum General Hardware Discussion
    Last Post: 06-06-2006, 05:00 AM
  5. Forcing Windows to recognize USB devices on different ports
    By rsd212 in forum General Hardware Discussion
    Last Post: 12-31-2005, 08:27 AM
