Results 1 to 4 of 4
Thread: How do I ground my M2-ATX?
    Low Bitrate dLockers's Avatar
    Jul 2007
    I've got a short 8awg wire going from neg on battery to the chassis, is that it? I'm sure I need to run a wire from the M2 to the chassis also, which plug do I go off?
    Also:
    M2-ATX, how do I make it so I can manually turn it on and off? I'm leaving tomorrow on a camping vacation and haven't the time to wire in and automatic on and off via an ignition.
    FLAC muldrick's Avatar
    Jun 2004
    South-Central PA
    Check the manual.
    3 wires, positive, negative, and remote on.
    1 Positive = battery power
    2 Negative = negative battery
    3 Remote-on = Ignition switch.
    I think running the wires correctly instead of rigging it will take just as long.
    I don't recommend rushing it. I'd do it after the camping trip, and take your time. (lest you fry something)
    IE: Do not run a negative wire from the negative to the chassis on the M2-ATX.
    Good luck.
    AtmosUSA.biz, E-Cig Mods
    "A great smoking alternative"
    Oct 2007
    Why don't you want to run the negative of the M2-ATX to the car chassis? Isn't that the same as routing it back to the battery?
    Jun 2004
    South-Central PA
    Sure, that works, so long it's a good ground.
  1. Alternator Whine Only With Carputer
    By tbird2340 in forum Car Audio
    Last Post: 06-29-2007, 03:36 AM
  2. Did I break my M2 ATX?
    By CelicaGTS in forum Power Supplies
    Last Post: 04-29-2007, 05:36 PM
  3. m2 atx with hardoff=never
    By Nerd2 in forum Power Supplies
    Last Post: 04-10-2007, 09:53 AM
  4. Re-Ground HU or Ground Loop Isolator?
    By Incinorator in forum Car Audio
    Last Post: 04-20-2006, 08:52 PM
  5. Finding good ground to prevent Ground Loop
    By lookinco in forum Power Supplies
    Last Post: 11-04-2004, 02:23 PM
