Results 1 to 10 of 15
Thread: Slow down fan speed
    Low Bitrate Pint's Avatar
    Aug 2007
    Melbourne
    Slow down fan speed
    My PC is very noisy ..... I know you heard this 1000 times. - Sorry
    how di I cut into my 5volt rail to supply my case fans? any pointers would be appreciated. I'm thinking of using the powersupplyfrom my spare USB headers on the motherboard.?
    I'm also going to try a vacum pump to suck the air out (instead of blowing it in) and increase air flow. ( I can run the pump outside of the car)
    and sit the case on a laptop G-Pad aluminuim heat exchanger to try and drop it another few degrees.
    hopefully after all that it should be silent.
    Things to do
    • Bluetooth handsfree / Tidy up dash fabrication / Improve startup-shutdown time.
    Maximum Bitrate pRoFiT's Avatar
    Apr 2005
    Fresno, CA
    Just pull 5 volts from a hard drive power connector. RED is 5V YELLOW is 12V and black is ground. Done.
    1st. How are your fans connected now.
    2nd. Not better but....Less power consumption from your power supply if you run your fans on the cars 12volts. Just my thoughts on that. but then you have 13.8 to the fans.
    I would build a simple cheap 5 - 8 volt regulator from the cars 13.8 volts and connect the turn on to your accessory on switch. then run your fans from that. a simple lm7805 or 7808 can handle 1 AMP out and 9-28VDC in.
    Maybe someone else has a better way to do it?
    Um, I guess this is where you put something witty.WITTY
    My Web site, in the design stage. http://home.comcast.net/~cstrachn
    Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
    Aug 2007
    Melbourne
    Thanks pRoFIT.
    I will use the spare hard drive power connector option. I'm not to worried about the power consumption - My Fans are already powered from the PSU/motherboard.
    I tried a voltage regulator for something else and I remeber it got really hot. I don't really want the additionaly wiring effort.....
    One more question. I remember 3 wires that connect my fan. I'm assuming I can leave one of them connected to monitor my fan speed?
    Things to do
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    Very often 5V isn't enough to give the fan the required kick to get the motor spinning (try running two 12v fans in series and you'll see what I mean.)
    Rather than chopping and splicing and crimping and bodging, why not just do what everyone else has been doing for the past 10 years and buy one of these:
    Fanmate Fan Speed Controller
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    OR.. just get a newer ball bearing fan .. I replaced all mine even on my pc's at home.. its soo much quieter now...
    Aug 2007
    Melbourne
    Grrrmachine, I tried the fanmate, but I wasn't happy with it as i had to have more wires comming out of my PC and seperate controll units. If I housed them internally (not that I have the room), the heat generated by the controllers becomes a problem. They are no good for me, but they did prove slowing the fans down quitens them down enough for me.
    Strohj - I had a look at alternate fans and decided not do that for two reasons
    I've got two pretty good/new fans as it is (just a little too noisy for me).
    Sourcing better fans proved to be quite difficult......
    I'll stick with trying to run them on lower voltage with a heat exchanger to compensate for the decrease in airflow.
    Thanks for your suggestions
    Things to do
    Maximum Bitrate NiSlo's Avatar
    Nov 2006
    Gold Coast, Australia
    Google for Speedfan. It's a software based fan controller
    I installed my carpc into my pet Kangaroo, mate.
    Aug 2007
    Melbourne
    okay....
    I tried Speedfan but it wouldn't work with my ITX machine.
    also tried powering my fans with 5Volts but as GRRMachine hinted, they wouldn't start up.
    I had a look at quiter fans - but I could'nt find them in Australia and shipping was going to cost me an arm and a leg so I gave up on that idea.
    I've gone back to the Fanmate solution. I took the fanmate out of it's plastic and shortened it's cable then plugged them into my fans and squeezed them into my case.
    I also screwed a laptop heat exchanger - which is really just a piece of aluminium - to the bottom of my case to help with heat transfer.
    My PC is now running quite. Although a little hot. I'll see how it goes and as a last resort put in a vacum air pump to suck out air and improve cooling. I'll post some pictures when I get a chance tomorrow.
    Things to do
    Aug 2007
    Melbourne
    here's the heat exchanger and fan controllers
    Things to do
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    5V is often not enough to kick start your fans, but 7V is
    You make 7V by hookinh op the positive wire on the fan to the 12V rail, and the negative wire to the 5V rail. The potential difference is 7 V. I made a homemade fan controller for a case a while ago with a double pole single throw switch (i think thats the right name) anyway, I could select 12V, 7V or Off.....
    So what I made was High/low/off That sounds like somehting that may be useful to you.
    It cost me under 5 bucks as some fan controlers can cost $30. And if spce is tight this is more barebones
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  1. How to Speed up Road Runner
    By JohnWPB in forum RR FAQ
    Last Post: 09-15-2007, 02:58 PM
  2. Replies: 6
    Last Post: 11-15-2005, 08:13 PM
  3. Replies: 2
    Last Post: 08-31-2005, 07:01 PM
  4. Tip! Get speed cameras into Centrafuse/D3
    By Micke in forum Centrafuse
    Last Post: 07-07-2005, 06:33 PM
  5. VIA Epia MII 1200 fan speed/CFM?
    By Snootch in forum General Hardware Discussion
    Last Post: 05-27-2005, 04:21 PM
