1) It will turn on a few seconds after the ignition turns on. Then when the ignition turns off, it will wait 5 seconds, and then "press" the power button. If you have the power button set to hibernate in windows, then it will hibernate in 5 seconds. If you have it set to Standby then it will go into standby in 5 seconds. Then after 2 hours, it will "pull the plug". So if it is in hibernate, nothing much will happen. But if it is in standby, then you will need a cold boot next time you start.
2) Yup. Put a switch that has a ON-OFF-ON configuration. Solder 1 ON to ignition source, and the other ON to a constant source. So if it is on the ON ignition source, it will boot up normally. If it is on the ON constant source, it will always be on (need to run an update in the garage or something). If it is in the middle (OFF mode), then it will never turn on (cold mornings as you suggest).
LinkBack URL
About LinkBacks
