Results 1 to 8 of 8
Thread: Saab 9-5 Hardwired Audio for Carputer
    Oct 2007
    OK so I have been getting really excited about trying to design my own interface for my macbook or other laptop for my car, with a possible permanent Carputer to come down the road.
    My plan is to pull the radio out and replace it with a 7" Touch Screen found here on Mp3Car (the Lilliput was the one that caught my eye) and my Saab 9-5 has more than enough room in the glovebox to hide my macbook if i run the wires into it.
    The main problem i can forsee is how to wire the 8 speaker setup into a USB or Stereo Plug that can plug into my Macbook, as my knowledge of car stereos, while more than your average joe, is still fairly limited. would an amp of some sort solve this problem? because even if i could find a way to wire them i can't figure out how i could get enough juice to these to power them.
    If i was a bit to wordy- essentially what i'm trying to figure outhow to do is run my car's speaker system WITHOUT a traditional radio.
    Oct 2007
    *bump*
    Jan 2004
    Italy
    you definitely need an amplifier. PC's audio output needs to be amplified to be routed to speakers.
    Nov 2006
    Many modern cars have built-in, separate amps, so you may want to check on that...
    Oct 2007
    From what I understand the saab does have a built in amp but it's proprietary and heard that will cause issues, AND i'm not sure if it's separate or built into the head unit. Anyone know of a good resource where i can look it up w/o pulling everything apart?
    Newbie saabv4's Avatar
    Oct 2006
    Stockholm,sweden
    saab 9-5 has an built-in amp. check http://www.mitt-eget.com/saab/
    Feb 2008
    scotland
    so can we wire the car puter into this amp , cant seem to fine an answer?
    Mar 2008
    Ohio
    What if you run the macbook to an auxiliary port?
  1. Outputting from car audio head unit to home theater receiver
    By mach5 in forum General MP3Car Discussion
    Last Post: 05-31-2007, 12:20 PM
  2. 2005 BMW E46 CarX audio hook-up question?
    By reggs in forum Hardware Development
    Last Post: 09-24-2005, 04:06 PM
  3. CarPC audio problems
    By aal2000 in forum Car Audio
    Last Post: 09-07-2005, 09:40 PM
  4. Replies: 19
    Last Post: 12-04-2004, 06:37 PM
  5. Seperate VGA and S-Video with Audio
    By Fox_Mulder in forum General Hardware Discussion
    Last Post: 07-01-2004, 02:44 AM
