Results 1 to 2 of 2
Thread: Noob Cable Question
    Sep 2007
    NY
    Noob Cable Question
    Hi,
    I need to power a touchscreen and to do so I need an 8pin mini din cable. However, I don't have a female receptacle on my computer that will accept this cable. So,
    -Is there an adapter that will do the job? If so can anyone link me to it or at least tell me where to look because I can't find it.
    -Can i power a screen through a serial (printer) port?
    I keep finding minidin8 to serial (9 pin or 20, 25, etc.) Will that work? because i have no use for a printer in my car and the port is there.
    -How difficult is it to make the cable from the male/female cable end kits i keep finding for a buck a piece?
    -Can i just throw the end I need onto a usb cable and call it a day? (this seems unlikely mostly because it would be too easy.)
    It seems like the only thing I can find is a mini din to 25 pin serial or something similar. How can I make this work? Thanks for your help.
    -NoobInNeed
    Elsewhere
    You're going to make your own adapter.
    No, you can't power a screen through a serial or parallel port.
    the LCD will require 12v.
    Your best bet is to tap into a HDD power connector. The yellow wire is 12v black is ground and the red is 5v.
    How about the Wiki?
  1. VGA Cable Question (Pinouts)
    By Bugbyte in forum LCD/Display
    Last Post: 07-26-2005, 09:54 AM
  2. Dvd and hard drive on same cable question
    By zetecdan in forum General Hardware Discussion
    Last Post: 07-07-2005, 01:16 AM
  3. Noob Here with a question...
    By ImprezaRS-T in forum Power Supplies
    Last Post: 03-15-2004, 06:09 AM
  4. Alltech Elc.LCD cable question
    By subarump3 in forum General Hardware Discussion
    Last Post: 11-29-2000, 10:51 PM
