Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Liquid Cooling?
  1. #11
    Aug 2007
    There are a few coolants that are nonconductive. A search on google will provide all the info you need. I know that sells some (MCT something) and another is Fluid XP. Though I have read posts of devices shorting out with non conductive coolants (supposedly due to the differences between air and the substances as a dielectric).
  2. #12
    Dec 2007
    A non-conductive fluid is called a dielectric, examples of these are R134a - the refrigerant used in your car or 3M sells a line, one of the fluids is called FC72 I think. There are NO water based fluids that are dielectrics, there is NO additive you can put into water to make it non conductive.
    Some of the issues with using a water based system are freezing & organic growth, thats why they make antifreeze. You could build a system using this but it makes the water less thermally conductive. It just depends on your total heat loads you are trying to disapate & your expected ambient temperatures. You need to size the radiator to match these, bigger and you get closer to ambient with smaller fans, smaller & you need more air flow. You also have to be careful about dewpoint. If it's really cold in the trunk and you pipe this very cold fluid into a warm & more humid environment you get condensation - put some ice in a glass of water, that's what happens.
    Aside from the CPU/GPU you may need to cool your inverter as well, at least have it in a spot with good airflow.
    There are a couple of startups developing R134a based computer cooling systems you can learn more from their sites, try
  3. #13
    May 2006
    Perth, Australia
    If computers are your "main hobby", then I'd assume you're familiar with a lot of games that require at least an 8600GTS and dual-core Intel to run.
    You will have a VERY hard time powering these things in a car, as they consume a lot of power.
    Settle for a Pentium 4 system, with a Radeon 9800XT and that should be fine, provided your battery and inverter are of decent power.
  1. thermoelectric cooler
    By odleon in forum General Hardware Discussion
    Last Post: 02-24-2006, 04:02 AM
  2. FAQ: Cooling Your System
    By Bugbyte in forum The FAQ Emporium
    Last Post: 10-03-2005, 04:09 PM
  3. Another Cooling idea from a dreamer...
    By Sillydipstixs18 in forum General Hardware Discussion
    Last Post: 07-28-2005, 11:10 AM
  4. cooling control panel
    By Sillydipstixs18 in forum LCD/Display
    Last Post: 05-23-2005, 02:36 AM
  5. XP + soft cooling (hlt)
    By jshrieve in forum Software & Software Development
    Last Post: 07-24-2002, 04:45 PM
