Results 1 to 5 of 5
Thread: Newbie here...
    Newbie copter's Avatar
    Dec 2007
    Nor★Cal
    Newbie here...
    Hey guys.. I've been lurking for a while and its time to post. I've got 15+ years of 12v experience and a bit of computer experience. I currently roll a 04 Acura TL and a 06 Chevrolet Duramax. I'm wanting to carputer my Duramax with a modest sound quality set up. One 10" sub, two 7" Dynaudio mids and some compression horns for the top end. I'd like the display to occupy the factory dash location with the usual XM, FM, Nav, MP3, DVD, HDTV and the biggest goal of all, digital guages. I want to be able to monitor my turbo boost, exhaust gas temp and rear diff temp. I'd also like to be able to use my factory steering wheel controls as well (at least for the volume and seek).
    _____________________________
    06 BLACKTIE LBZ | GRAYSTONE METALLIC | MBRP 4" | AMP STEPS | KMC DIESELS | TOYO M/T'S | NCT/COGNITO 4-6" | BILSTEIN 5100'S | MAG-HYTEC DIFF COVER | HID'S | PPE XCELLERTOR |
    ______________________________________
    May 2006
    Perth, Australia
    All of the above is perfectly plausible and feasable.
    The Search function is your best friend.
    Check out the Engine Management forum for the diagnostics features.
    I don't know about your car, but you won't be able to monitor your exhaust temp or rear diff temp unless they already have temperature sensors installed and connected to your ECU.
    Dec 2007
    Nor★Cal
    Quote Originally Posted by Un_discovered View Post
    Thanks... The EGT and rear diff are the biggest problem. They're not connected to the ECU. I'm going to try and get the probes mounted and figure out what the output is and try to incorporate it into a digital dash.
    Dec 2007
    Nor★Cal
    I just thought about a possible pc that's just sitting around. I've got a Shuttle FV25 with PIII 1k and 320 gig of HD. Should I scrap the FV25 and start over? I've searched; it's OLD and some have had boards take a dump on em but other than that, any advice?
    FLAC bosstone74's Avatar
    May 2002
    Japan, Oregon
    Just make sure you get a power supply that will work it other boards. Try the Fv25 out for awhile. It's a great board. I've recapped 4 of them and have in my car or my house.
    BossTone74
  1. NewBie Saying Hi
    By steven_0 in forum Newbie
    Last Post: 08-13-2007, 09:58 AM
  2. Newbie, but not so newbie
    By comptech_69 in forum Newbie
    Last Post: 12-06-2006, 07:33 AM
  3. Links to FAQS in the newbie section!?
    By lostreception in forum Mp3car Forum Suggestions/Comments
    Last Post: 09-20-2005, 04:33 PM
  4. help a computer BUILDING newbie out....
    By jusatry in forum General Hardware Discussion
    Last Post: 02-11-2004, 03:39 PM
