hate for this to be my first post but one question, why? they are on a keyed source for a reason.
if you can turn the ignition on then it should be sending power. unless your not turning the key, which would cause there to be no power. best bet is to go spend 20 bucks on a new ignition switch and just fix the problem instead of trying to jerry rig something.
There are two wires, when legally jumpering across the ignition switch of a car you legally own, you should pick them both up with the 'hot wire', IGN and ACC. Please, for your ??? truck's sake, don't mess with the fuse box. Just tie the battery lead to the ACC wire(s) at the switch in addition to the ignition wire.... And if you have a 'hot' truck, please disregard my advice and then do the right thing and turn it in, it is Christmas time after all.
