Results 1 to 4 of 4
Thread: AMP specs for Pioneer TS-E 6960
    Dec 2007
    Hello,
    I am looking for specs on an amp to power two Pioneer Three way TS-E 6960 speakers. They have the following specs:
    200 W max music power
    60 W NOM power
    4 ohm impedence
    70 W RMS
    Thanks.
    Nov 2007
    Prety much any 2 channel amp would do the job.
    Dec 2007
    Thank you for your reply. Actually, I wanted to know the specs. This is what I think I need from reading of other forums (might be totally wrong understanding).
    - 2 channel amplifier with 4 ohm impedance and 35 W rms per channel.
    OR
    - single channel amplifier with 2 ohm and 70 W rms to connect the 2 speakers in parallel.
    Please correct the above specs and also add in valuable information. I want to know the specs as I will be connecting the amplifier b/w mp3 player and speakers (I have another thread going to seek help doing that).
    Anyway, so I need to have the amplifier input a audio level signal equivalent to my mp3 player out signal. The amplifier specs will help me more as I will be able to narrow down my choices on what will work. Unlike USA, I do not have an opportunity to return the equipment I buy. So what I purchase will stick with me whether it works or not. I need to do some good research before investing.
    Nov 2007
    Do you want mono sound? Presumeable not, so buy a 2 channel amp. As for power - anything from 15 watts to 100 watts would be fine.
    Most amps have input sensivities of 0.2-2v which is fine for conencting the headphone output to.
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. Engine Noise due to ground loop or amp?
    By matt11601 in forum Car Audio
    Last Post: 08-26-2009, 09:38 PM
  3. YES!!! Yet Another Amp Problem
    By CaptainTrap in forum Car Audio
    Last Post: 03-24-2007, 10:58 PM
  4. Replies: 3
    Last Post: 12-07-2004, 07:34 PM
