Ok, I'm sure I'll be bashed for this dumb question..-- but Where do you download RoadRunner? If you go to the main page under downloads-frontends-Roadrunner , you get a blank page. You can search the forums and find oodles of download links including the authors, but which files do you download? Source, binary, installer? What is UP TO DATE?
Pretty simple already:
Download wimamp 5.13, RR installer, latest rr binary file and a skin of your choice.
Install in order:
Winamp
RR installer
Unzip binary files over existing rr files
install skin.
Register the winamp dll.
Now, run config, set up your paths/options and "bob's your uncle"!
This will get you the basic functions of RR.
If you want to use the program to it's fullest..................well, now you have some research to do........................
Leonardo Da Vinci
Uh, simple? I am not sure this is a word that would be appropriate for use in a conversation about this subject. You have posed a perfect example in your "simple" steps... "Register the winamp dll" ?! Where in the Help files does this exist? Ok, I am sure the answer will be "SEARCH".... but if you didnt know about this , what are you searching for? I have read hundreds of threads on this skin and RR and this is the first I have heard of this. Maybe I missed it somewhere... what is it for? What problems will it cause if you don't have this file?
