Results 1 to 10 of 20
Thread: Xbox hookup
    Newbie Goliath08's Avatar
    May 2007
    South Carolina
    Where does everyone find these cheap lcd screens? I can't find them.
    May 2007
    South Carolina
    Xbox hookup
    The goal is to have my xbox as my car pc. I have altered my xbox so i could use apps and other things. Its essentially a computer. (Please don't ask how) I want to use just a screen and not a head unit. The xbox has rca jacks out so how would I connect my orriginal speakers using the rca jack. Is there some kind of converter or somthing so i don't have to buy an expensive radio thats fugly anyway.
    Elsewhere
    It's called an amplifier.
    How about the Wiki?
    May 2007
    South Carolina
    I guess im asking it wrong. My harness won't plug into an amplifer. I haven't had any experince with using an amplifier.
    Nov 2007
    there is a audio converter that u hook up to the speaker leads going to any speaker and it converts the signal into a rca jack so u can use rca wires to hook up to a amplifier. If you are talking about hooking the x-box up to the radio so it plays audio to the radio then you need a rf modulator that hooks up to rca jacks. check radio shack.
    May 2007
    South Carolina
    so i can get rca jacks and connect them to the end of the wire. How many outputs does an amp normally have. 6 7 ?
    Nov 2007
    a amplifier usually has inputs only, some amplifiers will have a output to connect to another amplifier.
    Constant Bitrate jontz's Avatar
    Dec 2007
    Osceola, IN
    OK, I think I get what you are asking. You want to take out your head unit entirely, correct? Once you take your head unit out, you have the factory harness that used to plug into your head unit. What you need to do is go to www.crutchfield.com. Once you are there, you can put in your make, model, and year of your car. It will tell you all of the speakers and head units that fit in your car, as well as a factory wiring harness. Obvisouly all you want is the wiring harness. Once you have it, you will have to buy yourself a four channel amplifier, assuming your car has four speakers (two up front, two in back). Using the wiring diagrams from the amp and the wiring harness, you should be able to hook the amp to the harness you bought, and then plug the RCAs from your xbox into the amp. I hope this helps...
    May 2007
    South Carolina
    exactly what i needed to know. Thanks Im going to add a sub as well though. So I need a 5 channel amp?
    Nov 2007
    5ch amp or a 4 ch with a RCA pass through and a mono amp for the sub.
  1. XBOX + Apache v2.6 + M1-ATX = problems?
    By arionl in forum Power Supplies
    Last Post: 07-18-2006, 11:46 AM
