Results 1 to 5 of 5
Thread: Computer shutdown issues
    Aug 2006
    I've searched and have not found a problem similar to mine, so I figured I was a newbie and decided to ask for help here.
    I currently have my computer installed in my car. It works fine, boots up great, and runs ok. However, the computer, upon turning off my car, instantly cuts the power rather than signalling the shutdown sequence.
    This has become a problem because the computer is not able to save the settings prior to turning off. Thus, when the computer boots up again, it does not load the settings properly. When I shutdown the computer manually and turn it back on, it loads the settings (skin color, time settings, current song playing, etc...) fine.
    So, is there anything that could be within the hardware or software that I could change to cause the computer to shutdown and save the settings?
    My current configuration is...
    Foxconn mobo
    X2 4200+ processor
    Running windows XP Pro (n-lited version)
    Let me know if any other information is needed.
    Mar 2004
    Little Elm, Texas
    power supply?
    Jan Bennett
    Aug 2006
    Ah, knew I was forgetting something... it's an Opus 250W.
    Aug 2006
    Any clues?
    Should I just configure it for standby?
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    There are a lot of configuration options, pins to hook up, jumpers to set.
    So open your instructions and take a look there to begin with.
    Lots of options...
  1. Holux GPS Trouble
    By mangus580 in forum StreetDeck
    Last Post: 11-26-2007, 08:56 PM
  2. Which would be the better computer to start with?
    By thylacine222 in forum Newbie
    Last Post: 06-23-2007, 09:32 PM
  3. Computer Crashed?
    By Rocky388 in forum General Hardware Discussion
    Last Post: 11-30-2005, 09:39 PM
  4. Power issues in 03 Mustang
    By tj!2k4 in forum Power Supplies
    Last Post: 12-22-2004, 01:16 PM
