Results 1 to 10 of 10
Thread: Noob Help - D201GLY
    Jan 2008
    Noob Help - D201GLY
    Hey forum. I'm working today on getting my system up and running. Here's what I've got so far:
    D201GLY motherboard
    120GB EIDE
    DDR2 512mb PNY
    So, here's the problem. I've plugged the hard drive into my old desktop and loaded windows. Everything works fine when I do that. Now, when I trasnfer that hard drive back over to the D201GLY and fire it all up, it'll bring up the "safe mode, last normal start, etc" for booting windows. No matter what I pick, it acts like it's going to load and then just restarts. It does this continually and won't start windows.
    Any suggestions?
    Thanks,
    Dan
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    32
    well that would be because your old desktop uses a different chipset than the d201gly... therefore you cannot install your os on one system and transfer the hard drive to the new system. There's really nothing you can do to solve this outside of reformatting and installing your OS directly on the d201gly.
    Live mp3Car Facebook Chat
    Jan 2008
    Norton, MA
    I have never loaded windows in this fashion before, nor am I a comp sci major or anything to give you a concrete answer. However I would say that due to you loading windows on a different machine (different hardware specs) that this is where your issues are coming from. Can you put the drive back into your old desktop and does it boot up properly?
    2005 Ford F-350 crew cab 4x4 6.0L SRW LWB
    Planning:
    [|||||||||-] 95%
    Parts Aquisition:
    [||||||----] 60%
    Install:
    [|||||||||-] 90%
    Finally getting Built
    Jan 2008
    That was the problem. I've loaded windows before but every comp I've transfered it to was the same build. Just got lucky that way. Thanks guys.
    Low Bitrate stroths's Avatar
    Jan 2008
    Dallas, Texas
    I know of one way to do it. Use a product by Acronis called Universal Restore. I have used it to transfer Windows builds from one PC to another with very different hardware. Of course this method will not be free. The workstation version costs about $30 while the Enterprise costs about 10 times that.
    I am sure there are free ways to do this, but this is the method I have used.
    Jan 2008
    after instalation windows you must run in safemode (press F8 in boot screen). Press win+break and delete chipset drivers. After that power off & start in your another motherboard.
    Low Bitrate maniaxzero's Avatar
    Apr 2005
    Queens, NYC
    Quote Originally Posted by Sonicxtacy02 View Post
    I will have to disagree with you on this one. I previously thought i had to reinstall the OS when swapping motherboards. All those BSOD would come up. But after I followed this guide to delete old drivers and install generic drivers.....everything worked perfect. Windows booted up on my new motherboard without a reinstall!
    I would definitely give that a try first before reinstalling the OS!
    Aug 2007
    sysprep works too
    there is a file on the xp cd that is called sysprep which you can use too.
    or you could remove all your drivers in the device manager (the one associated with the computer you are goiong to be loading from) and then it will reinstall new ones when you switch over, but this is sometimes a crap shoot.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Go back to old PC, goto device manager and make the iDE/ATAPI controller back to default/standard.
    then try in new PC.
    Maximum Bitrate Woofnstuff's Avatar
    Oct 2007
    Auckland
    i installed win XP pro with exactly the same board.
    i had it sitting on my test bench with a normal PC power supply, the 2.5" laptop drive, with adapter thing, and a normal cd/dvd drive
    windows installed easily on it.
    installing windows directly to the computer you want it to run on is always the best option. you get less system bloat and less chance of some old / wrong driver getting in the way and causing issues or a reduction in performance.
    and its probably just as quick to reinstall as it is to stuff about trying to hack the other install into working.
    also a good thing to go, is ghost (image) the drive when windows in fully installed but before you start installing your apps. that way if you put a wrong codec in or something goes unhappy you can copy the saved image back on in a matter of minutes.
  1. Intel D201GLY BIOS Petition, Mobo selection (C2D?) and test results!
    By Lope in forum General Hardware Discussion
    Last Post: 09-02-2008, 07:55 PM
  2. noob intruducing myself
    By Shott8283 in forum Newbie
    Last Post: 12-25-2005, 10:32 AM
  3. Are there any ebay traders to watch out for?
    By jeeplaw in forum Off Topic
    Last Post: 06-15-2005, 12:10 PM
  4. Noob School
    By oranjjrush in forum Newbie
    Last Post: 09-23-2004, 11:29 PM
