Results 1 to 2 of 2
Thread: 2007 Camry Stock TouchScreen
    Feb 2008
    Is it possible to use the 2007 Camry Stock touchscreen with a CarPC? I did a search on the forums but didn't notice anything pop up. Any help is always appreciated. =)
    Jan 2006
    In theory it might be possible if you could find out which wires are for video input. Then you need to figure out what type of signal it accepts (composite, RGB, etc.).
    I guess if no one else has found out, or if you can't find any usefu documentation about it, you could try looking at the back of your unit.
    If you're a bit hesitant about mucking around with your own system, perhaps visit the wreckers and buy the same unit as yours. Then you can muck around with that one.
  1. Camry 2007 carputer. What it is?
    By novorado in forum LCD/Display
    Last Post: 07-31-2008, 10:03 AM
  2. Replies: 14
    Last Post: 04-13-2007, 02:23 PM
  3. Replies: 1
    Last Post: 10-01-2006, 10:10 PM
  4. Replies: 6
    Last Post: 09-09-2006, 11:51 AM
  5. Replies: 13
    Last Post: 08-22-2004, 05:52 PM
