Results 1 to 10 of 11
Thread: How to attach an amp to the computer.
    Feb 2008
    Question How to attach an amp to the computer.
    Now days most computers use the old 3.5 mm jack for the output to speakers, now the problem, how dose one go about hooking up an amp. i know there are some amps that have optical inputs but most don't, dose any one know if there are audio cards that use pre outs.
    chears
    jason
    FLAC Machinehead's Avatar
    Jun 2007
    hijacks small portable city
    There's a great FAQ to get you started:
    http://www.mp3car.com/vbulletin/faq-...tereo-amp.html
    Constant Bitrate krnpimpsta's Avatar
    Dec 2007
    DC Metro area
    All soundcard outputs are basically "pre-outs." They're low level signals that can go straight to an amp. All you need is a dongle to convert 3.5mm jacks into RCA's. They're $5 at Radioshack, probably cheaper elsewhere if you look.
    Feb 2008
    Thanks for the info, so you just need to "hack" apart the 3.5 Jack
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    you don't need to hack apart anything... just get an adapter like this:
    Feb 2008
    oh ok, ive got one of them allready, however i dont konw where to get em from, i'll prob just have a look at my local comp shop...
    Thanks for your help, and i think others will be too.
    Aug 2007
    You said you already have one? So why do you need to go find them at the shops?
    In my system I'm using a SoundBlaster Live card with two stereo 3.5mm outputs (one for front L/R, one for rear L/R) to feed sound to my 4ch amp. If you have a 4ch amp you can buy a splitter to send the same L/R to both the front/rear.
    Low Bitrate Coldfusionpower's Avatar
    May 2005
    Malaysia , Asia
    last time im using a 6 channel sound card. and use the same thing like they said . a 3.5 phone jack to two RCA is the best way .
    PC --> adapter wire --> amp RCA input
    Soundcard --> adapter wire --> amp RCA input
    First 3 Version DONE ...but sold ..with the car .. now .. building another one for the new car .
    Coming Soon : CarPC 2.0 .. 40%
    Aug 2007
    That would only be giving you two channel.
    Feb 2008
    hello !
    I'm quite new to the audio field, and I need to connect my subwoofer to my sound card, I have a ESI Maya44, but I'm not sure if I need a special 'out' of the soundcard for that.
    The advantage of using a direct connection of the sub to the soundcard resides, as I've been told, in the use of the amp volume function for both the sub and the main speakers, and not 2 (when connecting the sub to the amp.).
    Thanx.
  1. Replies: 38
    Last Post: 11-30-2010, 06:04 AM
  2. YES!!! Yet Another Amp Problem
    By CaptainTrap in forum Car Audio
    Last Post: 03-24-2007, 10:58 PM
  3. Computer input on amp?
    By ClubFed11 in forum Car Audio
    Last Post: 01-05-2005, 03:02 AM
