Results 1 to 2 of 2
Thread: 2002 WRX carputer--critique please :)
    Feb 2008
    Alright, after much debate and research, I believe I've come down to what appears to be a final proposal for my system...Car audio components aside, here's what I've come up with:
    JetWay J7F3E-PB Mini-ITX AMD Geode 1.4
    BU-353 GPS (already purchased)
    Lilliput 629GL-70NP (LED backlight)
    WRX Mechatronix double-din mount kit for the Lilli
    200gb IDE HDD/1GB RAM is pending
    Now ideally the goal is to mount the board behind the screen, in the WRX mounting kit. Should be possible, the dimensions seem to be fine. However, given that the AMD tends to run a bit warm, I was wondering if this would cause any problems. If I understand my friend correctly, who has already done this in his car, the screen will be powered off the M2. Also, someone on this forum mentioned that the 2008 LED backlit screen may not work with the WRX kit?
    Let me know what you guys think, I'm eager to start buyin' more parts!
    Sorry if this thread is posted twice, I never saw the first one appear in the forum!
    Mar 2004
    Little Elm, Texas
    Newbie threads are moderated based on specific rules. If you would like to read more, I suggest heading over to the suggestions forum. There's a sticky in there that will help describe it.
    As for the screen, I'd suggest sending an email to the store to find out for sure since the casing has changed between the two models.
    Also, I'd recommend going with a SATA drive over IDE and use a locking SATA cable. Smaller, better airflow, faster throughput.
    Jan Bennett
  1. 2006 Subaru wrx Sti carputer to stock speakers?
    By ultrA_Cowboy in forum Car Audio
    Last Post: 01-14-2007, 04:40 PM
  2. Carputer TIME!! please HELP!!
    By CoupeE46 in forum Newbie
    Last Post: 11-26-2006, 05:52 PM
  3. CARPUTER 2002 Accord FINISHED!
    By aznblueeboi in forum Show off your project
    Last Post: 08-18-2005, 10:37 PM
  4. carputer install: I dare you...
    By Cat Monkey in forum General MP3Car Discussion
    Last Post: 01-27-2005, 05:34 PM
  5. 2002 Alpine Class A RV Carputer in dash w/mounted 10.4 LCD
    By ProjectDinero in forum Show off your project
    Last Post: 06-14-2004, 08:37 AM
