Results 1 to 10 of 20
Thread: Valet Switch HELP!
    Oct 2007
    Springfield, MO
    Valet Switch HELP!
    So i've started working on the small pieces this project simply because that is what i can afford. So last night I made a radio shack run and bought a 6x3 project box and two automotive switches. I've already wired and put them together but want someone to tell me I did this correct. Power (obvious) ground (obvious) but Acc (is this the wire i'll run to my Computer?) please help!!! I don't want to install something wrong only to fry a 300 dollar piece of equipment when i only make about 1/2 of that in a month, sucks being a college student.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by Nickwell24 View Post
    I want someone to tell me I did this correct. Power (obvious) ground (obvious) but Acc (is this the wire i'll run to my Computer?)
    it sounds like you're using a lighted switch. lighted switches work the same as any other SPST switch, but they also have a ground lead (to ground the bulb). so to answer your question... yes, the switch's "ACC" lead goes to your computer.
    NOTE: if you want to use it as a valet switch (as opposed to a main power switch), then your main power should go through a relay switched on/off by your car's ignition or ACC line. you can then install a switch on the IGN or ACC line to act as your "valet" switch.
    this is what I mean:
    Oct 2007
    Springfield, MO
    Could i simply use this as a power switch? that way i just flip it on the turn on the com and don't have to mess w/ remembering to cut power from it?
    Oct 2007
    Springfield, MO
    If not that, how do you wire a relay, and how exactly do relay's work
    Mar 2008
    why not just wire the power to your ignition? i'm new to this but it would just be like audio right? or is there a remote wire? is there a memory wire so you dont lose all your stuff you have saved?
    Oct 2007
    Springfield, MO
    the reason i don't want to direct wire it is so i have the option of if it will turn on or not.
    May 2007
    Boston
    Quote Originally Posted by skystitt View Post
    you should NOT power anything directly off the car's ignition or ACC wires. these wires are not 'general use' power wires, they are specific circuits for specific purposes. the wires and fuses are large enough to power what came with the car from the factory. if you add things (like a carPC) then you need to run your own power wires to the car battery to power them.
    you can use the IGN or ACC wires as a signal wire to control a relay, but you should never power any device directly off the car's IGN or ACC circuits.
    May 2007
    Boston
    a relay is basically an automatic switch. it uses an electromagnet to open/close a circuit that would otherwise have to be opened/closed manually by flipping a switch, pressing a button, etc.
    with a relay, you can control a high current circuit (carPC) with a low current circuit (IGN or ACC). in this case, the IGN or ACC line will be used as a 'signal' wire. it is not directly powering any device, it's only providing a small amount of current to power the coil which will close the circuit (automatically "press the switch").
    a standard bosch style relay has 4 or 5 leads, numbered 30, 85, 86, 87 (5-lead versions also have an 87a). two of them are for the coil (86=power / 85=ground). 30 is the high power input (car battery) and 87 is the relay switched output in the 'closed' position (on 5-lead versions, 87a is the switched output in the 'open' position). when you apply low power to the coil, it physically pulls the internal switch to 'close' the high-power circuit (connecting 30 with 87). when no power is applied to the coil, then the high-power circuit is left 'open' (on 5-lead versions, 30 and 87a will be connected).
    wiring your main power through a relay will allow your car to automatically switch power on/off to the PC just by turning the key. (mechanical relays are cheap. they only cost about $5-$10 at an autoparts / electronics store)
    Oct 2007
    Springfield, MO
    Okay if i'm doing a laptop install is it safe to run power through the cig lighter for them?
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    Think of the future....
    If you get hooked on this like so many of us, you will be glad that you did things as well as you could at the beginning.
    I is really easy to carefully plan a hole drilled through the firewall of your car to run the power cable. Best Buy and such have install kits that come with large gauge cable, intended to be connected directly to yr car batt through a fuse:
    http://www.bestbuy.com/site/olspage....equestid=55928
    http://www.partsexpress.com/webpage....ctGroup_ID=731
    There are firewall grommets to pass the cable through, then you can give it a squirt of silicone caulk for good measure.
    The kits come with a power distribtion block, that once screwed in a location of your choosing, has several output connections for our carpc, screen, amps, whatever...
    12 volt power is a big issue and should be done as best as you can. It's one thing I did right the first time. A car fire, or even a little smelly smoke really puts a damper on the fun.
    blessings and good luck!
    Happy CarPC'ing!
  1. this is how to bypass laptop button and standby switch
    By andyman in forum Laptops, Netbooks, Tablets, UMPCs, etc.
    Last Post: 12-18-2007, 04:52 PM
  2. Power Supply/OPUS Kill Switch
    By SpaceMonkey in forum Power Supplies
    Last Post: 08-11-2006, 11:58 AM
  3. New product - PC Power switch with wired remote
    By hd54321 in forum General Hardware Discussion
    Last Post: 03-08-2006, 11:48 PM
  4. Car Window Switch Replacement
    By alienjj in forum Hardware Development
    Last Post: 09-05-2005, 01:08 PM
  5. Savage Switch Botton Group Buy via UK's Iconstyling.com....
    By TheBigDog in forum General Hardware Discussion
    Last Post: 07-21-2004, 11:51 AM
