Results 1 to 10 of 11
Thread: Powering neons with remote & switch?
    Mar 2008
    Ohio
    Total newbie here!!! I was wondering if someone could help me with a question I have. I would like to be able to power my underbody neons by either using a switch that's in the car (it's a lighted switch), or by the aux. button on my remote starter. I believe I would need to use a relay...but I'm just not positive on how everything would hookup. I'm attaching a diagram below...if someone could tell me how I would go about hooking this up I would really appreciate it. I wasn't sure if I would also need to use diodes?
    Mar 2008
    Ohio
    Quote Originally Posted by sigman70 View Post
    One more thing - remote aux output can be set to pulsed, timed or latched and shows as (-) 500mA.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    I added the wiring to your diagram
    the "aux" on your remote starter is probably live only when the remote starter is running the engine. as soon as you turn the key, the remote starter shuts off (and shuts off the "aux" function as well). if it's independent of the starter itself, then you may be able to use it. just wire the "aux" (+) output wire to lead 86 of the relay.
    good luck
    Mar 2008
    Ohio
    Quote Originally Posted by ComputerGeek View Post
    good luck
    Thanks for that!! According to the manual, the aux output wire is actually negative - it says "Auxillary Output (-)500mA" - and it can be set to pulsed, timed, or latched. Do you think I could just wire this aux wire along with the Acc wire from the switch to lead 86 of the relay? I might have been confusing on what I'm hoping to do...I want to have the option of using either the remote or the switch to turn on the lights (so if I'm outside of my car, I could hit the aux 1 button on the remote and turn them on and off...or if I'm in the car I can use the switch to turn them on or off). Thanks!!!
    May 2007
    Boston
    hmm...
    what does the manual say about wiring the "aux" output?
    Mar 2008
    Here is how to Properly Wire it up with both alarm and Relay.
    When Fusing make sure you put the fuse as close to the power source as possible. You should be able to use a fuse inline that is the same Amperage as the one on your D-block.
    Good luck, hope this helps
    EDIT: Diodes in diagram are in reverse bias by accident intall in forward bias
    AND your Acc wire off the switch should not be connected to the 12v input (line over extended) this will completely bypass your switch
    Mar 2008
    Ohio
    Thank you sooooooooo much! I really appreciate that!!!!
    Mar 2008
    Ohio
    OK, I have this setup like the picture shown below and I'm able to turn the lights on and off by either the switch or the remote. What I was wondering is could this setup be modified so that if I turned on the lights by the switch, I could then turn them off by the remote (and visa versa)?
    Mar 2008
    Ohio
    If anyone has any idea on this, I'd appreciate it. :-)
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    You would need to change the switch and relay to SPDT types and then wire them in series. At present you have just SPST types in parallel.
  1. Replies: 7
    Last Post: 12-14-2009, 08:34 AM
  2. xbox + inverter + remote start + relay switch
    By ozstriker78 in forum Power Supplies
    Last Post: 08-24-2008, 09:44 PM
  3. Powering up latop with manual switch?
    By black06stang in forum Newbie
    Last Post: 09-26-2006, 09:37 PM
  4. EASY remote switch mag light?
    By spectrrr in forum Off Topic
    Last Post: 05-27-2004, 06:23 PM
  5. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 06:27 PM
