Results 1 to 8 of 8
Thread: usb question
    Mar 2008
    usb question
    two questions
    1. is it possible to us a usb power cord you know the ones that get used on 2.5" external hard drives that don't get enough power from the usb to power a usb hub.
    2.where can I find usb ports to hook up to the pins on the mother board to add more usb ports
    Newbie DanaDeth's Avatar
    Mar 2008
    SF Bay Area, California
    Quote Originally Posted by jpbody View Post
    Something like this? http://www.newegg.com/Product/Produc...82E16815104225
    Variable Bitrate brucedog's Avatar
    Oct 2007
    Philadelphia, PA
    How about looking into a multi-port USB hub?
    Plugs into your pc's USB port, and splits it into 4 ports:
    http://store.mp3car.com/category_s/32.htm
    Happy CarPC'ing!
    Mar 2008
    power
    ok then if I put a usb hub to spit it to 4 how to i get the power to the hub if someone could tell me step by step instructions that would be great
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    If your powered hub uses 5v (it will say on the power brick, or on the back) then you can tap into one of the molex plugs on your carputer...(they are the 4 pin white plugs you stick in the hard drive)...Off the top of my head I don't remember which pin is 5v...but you can use a voltmeter and find out yourself...the two black wires are ground.
    If your hub isn't 5v, then you will need a regulator to supply around 2amps at your voltage from 12v.
    Oct 2007
    Philadelphia, PA
    I guess that some users need more current from their USB hub, but I ran the USB cable from the rear of my car to the front, and plugged the hub into the cable (it has reverse gender fitting).
    Plugged into my USB 4-port hub
    >Griffing Powermate "volume" controller
    >GPS receiver/antenna
    >touchscreen (Lilliput 629)
    >extra port used for thumb drive, or whatever...
    In my case, the USB hub self-powers all those devices without the need for any other power source.
    Otherwise, you might need to do like Dodge suggests.
    Happy CarPC'ing!
    Dec 2007
    if you get a 4-port usb hub that is 5v you can use a psp car charger to power it, since they are 5v.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by DodgeCummins View Post
    Red = 5v+ and the black directly next to it is the ground
    Yellow = 12v+ and the black directly next to it is the ground
    1X Ainol Novo Flame Tab
    4X MK808b
    3x Perixx Touchpads
    3x 7 inch Screens
    1X 7 inch motorized Screen
    1x Win 7 PC
  1. Quick Question (USB, IR LEDs)
    By Un_discovered in forum Off Topic
    Last Post: 04-10-2007, 02:15 PM
  2. Question on powering USB devices off of 5v line on molex connector
    By S4Per in forum General Hardware Discussion
    Last Post: 11-03-2006, 02:44 PM
  3. USB DAC Question
    By kamikaze2112 in forum General Hardware Discussion
    Last Post: 09-15-2006, 03:32 PM
  4. My USB/Wifi troubles.
    By JPuma in forum General Hardware Discussion
    Last Post: 09-23-2005, 11:44 AM
  5. Lilliput USB driver CPU usage question.
    By AustnJPR in forum LCD/Display
    Last Post: 04-06-2004, 01:59 PM
