You could, but they wouldnt last long. You will need something to even out and regulate the voltage spikes that are inherent in cars power systems.
I have a xbox360 hddvd drive and a wd my book 320g external hd
the power brick on the hddvd drive outputs 12v at 2.5amps and the brick on the Harddrive outputs 12v at 2.0amps, if i get a power port plugin with the proper tips to plug into the drives could i power them?
Car Pc progress meter:
[-----------------85%---] Looking good! Total spent : $740, Thats including two touch screens!!!
"The car is the closest we will ever come to creating something that is truly alive" -Sir William Lyons
My worklog
so are there plugin that are regulated or would you need a power supply to do that? i am thinking of using them for updating and file transfer so i dont have to pull the whole thing out of the car. they would be unplugged before i started the car.
BTW your car's alternator normally produces 14 volts.
