Results 1 to 3 of 3
Thread: Setup Power Question
    Mar 2008
    Just wanted to get an opinion from some of the more knowledgeable ppl here.
    I have the following setup as a 'project pc' that's not really used much anymore. I would like to place it in my Mazda 3 but I'm not too sure on the PSU I'd be needing to power it. I've been told to stay away from an inverter if possible...
    Setup
    Mobo: MSI P6N 650i ATX LGA775 Intel
    CPU: Core2Duo T8100 (It's fairly new...)
    Vid: XFX GeForce 8600GT PCIeX16
    Sound: On-Board Audio ( for now.. )
    Ram: 1GBX2 Kingston DDR2 800 240-Pin
    Hard Drive: Seagate Barracuda 400gb sata ST3400620AS (I think... It's newer too)
    I plan on having a few usb devices play it safe and say 4. I want to run at least 1 ir cam and possibly another backup cam. That's for future install though.
    Note: I also have an old 250gb Laptop sata drive I pulled about 6months back. I don't have the model info on it tho.
    The following psu calculator set the recommended level at ~250. This seemed low to me. I did look for my docs for the various parts listed above but they hav been lost in the trash can
    http://extreme.outervision.com/PSUEngine
    I was looking at the Opus 320Watt PSU but still that seems low as the Power Supply in the PC at the moment is sitting at a comfy 500Watt.
    The reason I want to try and stick with my parts listed above, save the fact I already have them for free, is that I run a beefy install of Ubuntu on it and would like to keep that as my CarPC interface. Saves on install time. Plus it just works and looks bad ***
    Any feedback is appreciated!
    Thanks.
    Elsewhere
    A couple suggestions and observations:
    1 - Lose the high-end video card. You're simply not going to need it in the car. Get a lesser video card.
    2 - You're really not going to need a second hard drive. It only adds to the power draw.
    How about the Wiki?
    Mar 2008
    I was considering the option of using the 2.5 laptop dirve in place of the mentioned 3.5 drive if i needed to save the power
  1. FAQ: Power Supplies Explained (Part 1)
    By Bugbyte in forum The FAQ Emporium
    Last Post: 06-10-2007, 08:45 AM
  2. Carputer Setup and power rewquirements
    By driller in forum Newbie
    Last Post: 10-08-2006, 04:15 AM
  3. Newb question about power from a Molex
    By dsballer2000 in forum Power Supplies
    Last Post: 06-25-2006, 12:32 AM
  4. FS: ITPS shutdown controller and PW-70a MINI-ITX power supply
    By hanzacra in forum Classified Archive
    Last Post: 08-07-2005, 11:32 PM
  5. Controlling your power setup remotely
    By auto_robotics in forum Power Supplies
    Last Post: 10-08-2004, 08:05 AM
