I am assuming in the BIOS, it will ask what you want the default screen to be. I also know that under screen appearance, you would select the external screen as main monitor. Usually though you dont have to set anything, if the last thing you used was the external it should just start up to that.... On my Gateway I have an external monitor because the original screen broke. The only time it will try to go back to the broken screen is if the battery completely dies.
LinkBack URL
About LinkBacks
