Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: FM Transmitter (How does it work?)
    Low Bitrate The1Architect's Avatar
    Apr 2008
    Winnipeg, Canada
    i have a FM Transmitter that am not sure if it will do the job for me or not.. am not even sure if any FM transmitter should work or there are specific ones for this kind of job
    the one that i have is a basic fm reciever that cose with an instant radio software for a pc like this one:
    ADS Instant FM Music RDX-155-EF
    if it should work with road runner can someone please tell me how to congif. it?
    this is the link to the product on the company website:
    http://www.adstech.com/products/RDX-...pid=RDX-155-EF
    Mar 2006
    Colorado, but Canadian!
    are you talking about FM transmitter (send audio from source to radio) or FM receiver (takes radio into sound)? You used both in your question...
    1.9in x 2.9in -- 47mm x 73mm
    FLAC greatwhite's Avatar
    May 2007
    Top o' the world Ma!
    I don't understand exactly what your question is.
    Are you trying to get the sound to the head unit or to the computer?
    Please elaborate and be a bit clearer with your question please.
    I assume to the head unit. If so, you tune your radio to the fm transmitter frequency and it plays through the head unit.
    The big drawback to this is that you are limited to fm radio sound quality. If it's a transmitter (what it looks like in the picture provided) and not one of the units that goes inline with the antenna lead, you can get interference as well...
    Leonardo Da Vinci
    Apr 2008
    Winnipeg, Canada
    sorry guys english is not my first language
    i will try to break it down to basic questions
    the front end for the car pc has the option of playing radio channels (FM 99.9, FM 102.1, etc...)
    the device the i was showing in the picture above plugs in to the computer and recieves fm signals and makes my pc plays FM radio channels
    the problem is .. it has its own software (instant radio) and am not sure how to make road runner take advantage of this FM reciever ( or i guess i should call it tuner?) and play the fm channels
    basically i want something that does what this device does.
    Mar 2006
    Est-ce que vous avez le fichier "USBRadio.dll" en votre dossier de RoadRunner?
    Avez-vous déjà acheté la radio d'USB? Si vous ne l'avez pas acheté, je suggère le HQCT: http://store.mp3car.com/ProductDetai...ctCode=COM-009
    Dans RRConfig, il devrait y a une étiquette "FM Radio" avec tous des choses que vous vous aurez besoin pour votre radio.
    Apr 2008
    Winnipeg, Canada
    I guessed that was french and i was right so i google translated it and read it in english
    Do you have the file "USBRadio.dll" RoadRunner your record?
    Have you ever purchased radio USB? If you have not bought, I suggest the HQCT: http://store.mp3car.com/ProductDetai...ctCode=COM-009
    In RRConfig should label is a "FM Radio" with all of the things that you will need for your radio.
    thanks for trying but my 1st language is arabic
    so i guess staying with english would work better
    so i got the part of where you asked if i have USBRadio.dll .. yes i do but can you please provide more details (sorry a Newbie what can you say :P) and i do actually have an FM tuner but not sure if it would do the trick
    May 2007
    Hmmm, if I had to guess, I bet it's using the silabs chip. Select the "silabs" option in RR config and see what happens.
    Search for "silabs" and "road runner" on the forums for more info, it's been discussed many times.
    You may want to try the "radiator" option in the RR config application as well.....
    These are my best guessed as I've only ever used radioshark and the visteon hd radio.
    Good luck.
    Leonardo Da Vinci
    FLAC Griff1's Avatar
    Nov 2005
    Midlands
    Hi The1Architect,
    There has been a few advance's with this Tuner lately so your in luck.
    The tuner in question is Silabs chipset based and supports RDS/RDBS but the original usbradio.dll didn't do a very good job of decoding the info but some clever guy's on http://www.digital-car.co.uk/ have improved things 100%.
    There's also a sound quality issue with the unit in the form of an intermittent tone which is clearly audible if tuned to a talk station (the original Silabs unit doesn't have this issue)
    The guy's working on it have fixed this issue too.
    Here's what you do......
    Download the latest RRConfig or check that the one you have has the silabs radio option under RADIO.
    Plug in your unit and select silabs in RRConfig then save and exit.
    Download this = http://innovatedaudio.com/griff1/ADSConfig.zip and run the ADS config app and click on the "download firmware" button,you now select from "ADS NoiseMod.dec" which will fix the tone and allow you to use this version of the software = http://silabsradiodll.googlecode.com....7%20beta3.zip (download this and paste the USBRadio.dll into your RR install Directory)
    Alternatively you can choose to install the silabs firmware "Silabs Standard.dec" which will allow you to use this version of the software = http://silabsradiodll.googlecode.com...-1.7-beta5.zip (download this and paste the USBRadio.dll into your RR install Directory)
    The benefit of installing the silabs firmware is that the USBRadio-Beta5 has direct sound or ffdshow audio processing.
    Finally you need Guino's latest RR beta which supports the new RDS label,you can get that here = http://guino.home.insightbb.com/RoadRunnerBeta.zip (discard the usbradio.dll contained in the folder as its outdated now)
    I know thats alot to take in so if you fancy catching up on the whole story you can check out the thread = http://www.digital-car.co.uk/forum/s...ead.php?t=8867
    PS,Not sure that BMV skin has RDS support but i might be wrong,either way if you like that skin you should download BMV2 the updated version.
    P4 2.8 HT, 512Mb Ram, 60Gb 2.5 HD, M4-ATX, SB Audigy2, BU353, Lilliput TS,Soundgraph Imon VFD,SONY Optiarc dvd Burner,RideRunner, iGo8, Custom Freedom 2.1
    Apr 2008
    Winnipeg, Canada
    thanx alot Guys
    Griff1 that was really helpful your instructions were GREAT and SOOOO CLEAR I followed them step by step
    I know now that my tuner is working the way it should work with RR based on whats showing in these pics
    however, when i start the radio i start getting sound but its a straight soft noise "shshshs...."
    not the station
    Nov 2005
    Midlands
    Hi mate,glad i've been able to help so far.
    Which firmware and app did you go for? If you loaded up the silabs firmware then you need to unplug the radio for your pc to re install it as the silabs.
  1. Replies: 10
    Last Post: 12-26-2007, 11:59 PM
  2. Replies: 4
    Last Post: 09-28-2005, 08:25 PM
  3. Awesome Fm Transmitter
    By syfenx in forum General Hardware Discussion
    Last Post: 02-12-2005, 09:08 PM
  4. FM transmitter ... quality not what expected
    By Don 944 LA in forum General Hardware Discussion
    Last Post: 11-04-2004, 08:19 PM
  5. USB FM Transmitter
    By m3rdpwr in forum General Hardware Discussion
    Last Post: 09-13-2004, 11:11 AM
