Page 2 of 4 FirstFirst 1234 LastLast
Results 11 to 20 of 38
Thread: Disk boot failure
  1. #11
    Aug 2007
    ya its my first one but my friend is the one who put it together and its his second or third
  2. #12
    Jun 2005
    Atlanta, Georgia
    Just asking based on your statement above.... do you have a heatsink on the CPU and motherboard chipsets (the northbridge and/or southbridge)?
    Heat always has something to do with computers.. and it's not uncommon for them to "stall" when booting if something is overheated. Or, it could stop booting if the chips end up getting fried.
    I still think you have things connected incorrectly somewhere, or an incomplete computer build.
  3. #13
    Mar 2008
    Ok, you need your CPU in your motherboard. On top of your CPU you need a heatsink/fan. Then you need at least 1 stick of RAM securely pushed in.
    You need a hard-drive as well.
    If your hard drive has nothing on it, you will need to have a CD rom to install windows from.
    It runs the program from the CD and installs windows onto the hard drive.
    To me it sounds like your hard drive is not plugged in all the way, or it is an old bad one..or you don't have a hard drive at all.
  4. #14
    Aug 2007
    yes there are heat sinks, i only asked that cuz it was hot out and the sun was beaming down on my comp. and the hard drive is brand new.
    here is the pic of the screen i get
  5. #15
    Mar 2008
    Is that the only screen you get? Does it just stop there?
  6. #16
    Aug 2007
    yes, thats all i get
  7. #17
    Deactivated
    Apr 2008
    Boot Failure
    Try resetting the cmos (take the small coinlike battery out and put back in again). Also try taking all the components out you dont need to boot. The soundcard, cd-drive, any usb devices, mouse, keyboard, leave 1 stick of ram in. Also check to see if the jumper on the HDD is set to master or single device and not slave. It could also be down to the power supply make sure you have enough watts.
  8. #18
    Aug 2007
    ok took out the battery put it back in powered up and still get the same thing.
  9. #19
    Aug 2007
    I reset the cmos and still the same screen. Just to make sure, I reset it with the battery out right?
  10. #20
    Mar 2008
    Put the battery back in.
    Remove everything from your motherboard except 1 stick of ram and your hard drive.
    See what happens.
  1. Need assistance improving boot time - Windows Xp - 12s
    By hidddenh in forum Operating System Optimization
    Last Post: 02-12-2008, 05:15 AM
  2. Replies: 10
    Last Post: 04-17-2006, 06:23 PM
  3. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 07:03 PM
  4. EPIA M Network Boot Disk
    By slarty in forum Software & Software Development
    Last Post: 04-10-2004, 11:08 AM
  5. Enabling/Disabling Setup via boot disk?
    By gizmos in forum Software & Software Development
    Last Post: 07-14-2000, 11:39 PM
