Results 21 to 30 of 38
Thread: Disk boot failure
  1. #21
    Aug 2007
    do i just power up like that or reset the cmos like that?
  2. #22
    Nov 2007
    to reset CMOS you have to keep MB w/o battery for several minutes. at least 10 min to be sure it was cleared.
    how does it beep? one long? few short? count them. than try to find online the meanings. Not sure, but i think one long been means ram failure/missing. 4 short beeps - fried CPU
  3. #23
    Aug 2007
    Quote Originally Posted by Xoxol View Post
    i reset the CMOS like you said and there is no more beeping now, but i still can only get that same screen.
    edit: i was thinking... is there any way i can have something connected wrong even tho it worked one time before?
  4. #24
    Nov 2007
    well, it would be better if you had any beeping... At least would be easier to track the problem. Do you have spare parts like another Video Card, RAM, Sound Card, HDD? Try to play around, because it's really hard to tell what's wrong with it...
  5. #25
    Aug 2007
    no i dont, well this suks ive put a bit of time in getting all the parts and finally putting it in
  6. #26
    Nov 2007
    try to take it apart and do it again... sometimes it helps
  7. #27
    Jun 2005
    Atlanta, Georgia
    Consult the manual on how to reset the bios (aka cmos). You generally have to have POWER going to the motherboard (but the computer will not be on -- just powered), and you switch around a jumper. By power, I mean from a power supply -- you should just leave the battery in at all times unless there is no reset jumper. Then, do as Xoxol said.
    Can you even get into the BIOS? Check its settings for something unusual - even if you reset it as it may not reset.
    Anyways, do as people have said and have as few items as connected as possible. For example, start with only the following connected:
    • Power Supply
    • Processor (and its heatsink/fan)
    • Memory
    • Video card, but only if there is no onboard video
    The computer should start up, it should do a memory test, and then beep/give you errors. You'll most likely get a keyboard not found error. That's good. Turn the computer off, plug in the keyboard, and boot it up again. You should get the same thing, minus the keyboard error, but it should get further along until you get a message.
    ^^ Lather, rinse, and repeat until you get everything connected. If you get to a point and can't resolve the error message, or it just hangs, then troubleshoot based on how the computer is setup and what the last thing connected. There are too many possible outcomes to give you a step by step guide here.
    Alternatively, if you think it's the hard drive -- try setting the BIOS to boot from CD, and use a bootable CD to see what happens.
    It's going to be a trial and error process, but you'll find it. If you have the ability to make a video of exactly what happens from when you first apply power, that would be helpful to see. Or even if you can post some pictures of your motherboard setup so we can rule out other things.
  8. #28
    FLAC DodgeCummins's Avatar
    Oct 2000
    DFW area
    You should be able to bypass the splash screen by hitting maybe the ESC button.
    Is there a keyboard attached?
    Also read the manual where it tells you how to enter the BIOS. sometimes F2 sometimes DELETE keys.
    I think your hard drive is the problem...at best...so get into the bios, and see what it says about your HD...if it doesn't show a HD then guess what...
    While you are in the bios...turn off the splash screen so you can see what messages it is trying to tell you.
  9. #29
    Aug 2007
    So i booted up with what you guys were telling me and when i got to the point when i booted up with the HD removed i got this screen. Im guessing that my HD is the prob and i need to return it and get a new one?
  10. #30
    Nov 2007
    go to bios and autodetect hdd. or just manually set primary and secondary devices into auto mode and see if it detects your hdd. if not, try to switch from primary ide to secondary. if it still doesn''t detect, return your hdd.
    dont forget to save settings on bios exiting
  1. Need assistance improving boot time - Windows Xp - 12s
    By hidddenh in forum Operating System Optimization
    Last Post: 02-12-2008, 04:15 AM
  2. Replies: 10
    Last Post: 04-17-2006, 05:23 PM
  3. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 06:03 PM
  4. EPIA M Network Boot Disk
    By slarty in forum Software & Software Development
    Last Post: 04-10-2004, 10:08 AM
  5. Enabling/Disabling Setup via boot disk?
    By gizmos in forum Software & Software Development
    Last Post: 07-14-2000, 10:39 PM
