Page 4 of 4 FirstFirst 1234
Results 31 to 38 of 38
Thread: Disk boot failure
  1. #31
    Jun 2005
    Atlanta, Georgia
    Either you successfully reset you BIOS, or something was corrupted in it. Hard to tell exactly what since the screen is cutting of the message.
    Attach your hard drive to Primary master (and make sure the hard drive is set to be master). Then boot up again and go into the Bios.
    Go through every page of settings, make sure they are correct. Especially the CPU multiplier and associated settings. Make sure the bus speed is correct as well.
    Also check your boot order. Should be set to cdrom, then hard drive.
    Save the changes to the BIOS, and let it go through booting again normally. Should be set after that point.
    As an aside, you may also want to move you cdrom to Secondary Master. It's not a requirement, but it's the recommended spot for it in a single hard drive / single cdrom drive type of setup.
  2. #32
    Aug 2007
    ok so i went to auto detect the hdd and no luck at all, i did that in primary in secondary with no luck so its being shipped out for a new one.
  3. #33
    Aug 2007
    ok the replacement HDD came in and it is not readable either, but when i put a big HDD (on for a big comp) it reads it.... help plz
  4. #34
    Aug 2007
    Ok new problem, i got it to work and i am now installing windows and i hav an issue with the partition thing i go to create one and it doesnt create anything i press c to create and then enter the amount of mb and press enter and then nothing. any ideas or should i start a new thread somewhere else.
  5. #35
    Nov 2007
    looks like ram to me.
    try to pull out one of ram chips it you have more than one, if doesnt help, try to switch them.
  6. #36
    Aug 2007
    I only have one ram chip and i pulled it out and put it back in still the same thing. Think i need a new one? If so what would be the best type?
  7. #37
    Aug 2007
    got a new ram stick and still cant create a partition
  8. #38
    Aug 2007
    can a mod close this thread, im going to create a new one with a better title so i can get more help.
  1. Need assistance improving boot time - Windows Xp - 12s
    By hidddenh in forum Operating System Optimization
    Last Post: 02-12-2008, 05:15 AM
  2. Replies: 10
    Last Post: 04-17-2006, 06:23 PM
  3. Windows XP won't boot up anymore!!!!
    By Luderboy in forum Newbie
    Last Post: 09-03-2005, 07:03 PM
  4. EPIA M Network Boot Disk
    By slarty in forum Software & Software Development
    Last Post: 04-10-2004, 11:08 AM
  5. Enabling/Disabling Setup via boot disk?
    By gizmos in forum Software & Software Development
    Last Post: 07-14-2000, 11:39 PM
