Results 1 to 10 of 10
Thread: using laptop HD w/barebones system
    Dec 2007
    if i picked up a barebones system would i be able to use my compaq laptop Hard drive with it? I am getting pretty ****ed off because i try and wire up a button to turn the laptop on and off and it keeps breaking off, so i am looking at other routes.
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    as long as your "barebones system" uses the same HDD connector then it should plug right in. if it uses a different interface then you'll need an adapter or controller card, but you can still use it.
    NOTE: you can't simply swap the HDD and use it as-is. your current windows installation matches your laptop hardware and will not work properly with your new "barebones system". after you connect the HDD in your new system you will need to format the HDD and install a clean (non-OEM) OS onto it so that it sets itself up for your new hardware (make sure you backup any important data first).
    Variable Bitrate Grrrmachine's Avatar
    Sep 2005
    Warsaw, Poland
    Odds are your laptop is an old 2.5" IDE drive. Even if your barebones motherboard is IDE (not SATA) you'll still need a converter, but they're a matter of pennies from eBay.
    Dec 2007
    how would i format it?
    Low Bitrate blackmz3's Avatar
    May 2005
    Grand Prairie, TX
    i use one of these for my 2 2.5" hard drives in a 3.5" bay.
    2008.5 White MS3 Sport
    Cobb Shifter Weight | Cobb SRI | Cobb AP | Cobb Turbo Inlet
    HKS BOV(Recirc) | Defi Boost Gauge| TRZ Tranny Mount| F2 BSD | F2 Oil Baffle
    Dec 2007
    Okay so what would be the process to get it working? How would i format it? Would it format when i installed an OS? I only know the basics when it comes to computers so any information would be great.
    May 2005
    Grand Prairie, TX
    yeah toss in the os and go from there.
    Sep 2005
    Warsaw, Poland
    Make sure you have a bootable OS install disc BEFORE you wipe the drive out of the laptop and mess around with it, otherwise you'll have two dead computers!
    Dec 2007
    Okay i have been looking at getting Linux, since i dont want to spend another 100 bucks on getting XP, does anyone know anything about it? Will it be compatible with my lilliput and my gps software? Do i need a special front end or can i DL any? I looked thru the linux forum and theres not really a FAQ.
    Constant Bitrate golfguy's Avatar
    Nov 2006
    Fort Worth, TX
    If you don't yet know how to format a disk for Windows, I wouldn't recommend you make the leap to Linux. Many aspects of Linux are not very user friendly and can require some knowledge of the system to get properly configured. Stick with Windows and build up some experience before you try something like Linux.
    Any day is a good day for golf.
    Mazdaspeed6 Carputer Progress: Gone
    (Check Speedy's Install)
    Speedy was traded for a 2004 350z - Install complete except for permanent screen installation.
  1. WTB: laptop dvd-rom or dvd burner and laptop hd
    By macmini in forum Classified Archive
    Last Post: 09-06-2005, 01:11 PM
  2. Replies: 1
    Last Post: 02-03-2004, 08:07 AM
