Page 16 of 21 FirstFirst ... 6789101112131415161718192021 LastLast
Results 151 to 160 of 206
Thread: 2007 Honda Civic SI Coupe Carputer install [Updated]
  1. #151
    Dec 2007
    Iowa
    Oh and by the way i have a 15 second boot time now :-D and this is before adding minlogon fix
  2. #152
    Dec 2007
    Iowa
    Custom Double Din Case
    So here is my idea. The dimensions behind my dash ,base approximation only, I have 5.5"x4.5"x7" and that is DepthxHeightxWidth. So i figure there is no way i can do this in a nice 2D fashion so i took it to 3D
    This is what i'm going to try and fabricate
    I'm going to take some right angled corners to secure the board but that shouldn't be too bad. I figure the most likely scenario is that most of the cabling will be going down out of that compartment. So i think this might be possible. Any thoughts?
  3. #153
    Dec 2007
    Iowa
    Ok i completely scrapped the idea of putting it in my dash it just doesn't seem worth wild. If you put everything in the dash you can be robbed quite easily and then everything you fabricated is gone And you have less ventalation.
    Anyway moving on. So i'm mounthing the carputer in the trunk and trying to get Nexson to fab a dashboard for me.
    If someone can possibly show me how to wire up a powered USB hub. I know i can use 5V from the power supply and i'm thinking that all you do is cut off the tip of the power cord and splice those wires with the 5V and GND from the PS. Is this correct?
  4. #154
    May 2008
    glad to see you got it working.
    about the usb hub, is there an advantage to running an externally powered unit? seems like there are plenty of units that don't require an adapter and they're fairly cheap.
  5. #155
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    One of the pins on a USB cable is 5V, so you can rig up a USB cable with 5V and GND connected to the pwr source and the other two wires carrying data back to the PC's USB plug. Or, if the hub has a wall adapter, see if it takes 5 or 12 V and wire pwr and gnd directly into the adapter and use normal USB cable connected to the PC.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
  6. #156
    Dec 2007
    Iowa
    Quote Originally Posted by BLACKonBLACK98 View Post
    The USB hubs that aren't powered don't allow you to get the necessary range. The powered USBs buffer the signal, so its like its right at your motherboard all over again. I believe USB is rated to 15ft but i doubt u'll get the necessary amperage at that length.
  7. #157
    Dec 2007
    Iowa
    Quote Originally Posted by galvitron View Post
    This will work only if the USB only needs 500mA of current. If its stupid high like the cd drives it may need like 2A and usb ports just to provide that much amperage. Its actually really easy to power a usb hub off the power supply just took a little big of digging to get all the information. I can just get a little circular jack and wire it up with a power wire from the power supply and a get a ground wire and i'm good to go. I thought it was going to be a little more difficult but oh well
    I'm also thinking about just making a regular box that has numerious outputs from the unregulated 12V battery. Those regulator chips are like 1.50
  8. #158
    I bought a powered USB hub. I got the AC wall plug, cut the wires and spliced into the PSU's 5v rail. Easy peasy and works great!
    Off the hub, I run my OBD, bluetooth, touchscreen kit and charge/sync my phone.
    Although I thought maybe I am putting too much strain on the 5v rail of the PSU? VIA's run off the 5v rail, as do hard drives......lol
  9. #159
    Dec 2007
    Iowa
    i'm a little worried about that as well. Once i get my case i'm gonna see if the power supply can handle it. i hope so.....
  10. #160
    Dec 2007
    Iowa
    Com Port Plugin
    For all of you guys who are centrafuse fans like i am now I created a Com port plugin for centrafuse that will allow you to send a command through the com port and centrafuse will interpret it and execute certain command.
    The command list i designed was for utilizing steering wheel controls as well as setting up the voice control like AvWuff's project which i just thought was amazing. Thanks AvWuff for the help.
    Command List
    SN - Next Song
    SP - Previous Song
    VU - Volume Up (Without a dialog box)
    VD - Volume Down (without a dialog box)
    VC - Toggle Voice Command
    If you want me to add more commands let me know. I can do it but it just didn't seem like many people would need more than just those.
    Attached Files Attached Files
  1. 2006 Tacoma Carputer
    By rac3pm in forum Show off your project
    Last Post: 04-21-2009, 01:54 AM
  2. Carputer build. Need help
    By dizbo66 in forum Newbie
    Last Post: 05-27-2008, 12:51 AM
  3. Replies: 5
    Last Post: 05-31-2007, 05:46 PM
  4. Carputer build, setup and design
    By stalkerstyle in forum Newbie
    Last Post: 02-02-2007, 11:27 PM
  5. How to build your carputer at a liquor store
    By C4M in forum General Hardware Discussion
    Last Post: 09-14-2002, 03:45 AM
