Page 1 of 21 1234567891011 ... LastLast
Results 1 to 10 of 206
Thread: 2007 Honda Civic SI Coupe Carputer install [Updated]
    Dec 2007
    Iowa
    Hey all. I've been on this site for quite some time looking up info on building a carputer. I'm putting in my 07 Honda Civic Si and I'm still in the research phase of my build so tell me what u think of my current specs.
    Updated Configuration:
    Case - Mobile Computing Solutions Case
    Power Supply - M2-ATX 160W Intelligent DC-DC PSU
    RAM - 1GB DDR2 667 (wish i had a 1GB stick but i don't)
    Processor - Intel Yonah T7100 Core Duo 1.80Ghz 1.80/2M/800/SLA4A
    TV Tuner - None yet but hope to get Pinnacle PCTV HD Card - ATSC HDTV \
    Motherboard -Gigabyte GA-6KIEH-RH Minitx
    Wireless Card - Intel Mini-PCI Express 802.11 a/b/g/n
    Satellite Radio - XM Package (XMD-1000) + USB adapter
    Front End - Centrafuse 2.1
    Screen - Linitx Transflective Screen
    Bluetooth - Generic Bluetooh Dongle
    Primary Harddrive- 32GB Patriot SSD
    Secondary Harddrive - Seagate Momentus 7200.2 200GB 7200 RPM SATA 3.0Gb/s
    Microphone - Andrea Electronics Superbeam Array Microphone Bundle
    GPS - BU 353 GPS Dongle
    USB - Dlink USB Hub (powered of course )
    VIDEOS
    -Standby S1 Demonstration
    [media]http://www.youtube.com/watch?v=y3TO9RZPtjI[/media]
    -Hibernate Demonstration
    [media]http://www.youtube.com/watch?v=z7dpO4kHL90[/media]
    -Cold Start Demonstration
    [media]http://www.youtube.com/watch?v=_nO5WAhNNNQ[/media]
    -Functions Demonstration
    [media]http://www.youtube.com/watch?v=6BdR9Kwt6Bk[/media]
    MY NEW Case from Mobile Computing Solutions(Modified by me for better air flow)
    New Dash Piece
    _
    Mar 2004
    Little Elm, Texas
    Have you researched your selections here? Have you researched reliability on the hardware and support for the software?
    I'd HIGHLY suggest that before you go much further.
    I'd HIGHLY suggest reading up about the Bluetooth dongle before diving in and waiting for it.
    Jan Bennett
    Dec 2007
    Iowa
    I assume this bluetooth dongle will work with streetdeck I thought this is the one that was being used with the Infill G4. Its from the Mp3car store. Am i wrong?
    Newbie redcell3's Avatar
    May 2008
    nunya
    Really
    Do more research, you are way overpowering it with that core 2 duo, and 2gb RAM IMO, unless you plan on using AutoCAD or playing COD4, i seriously doubt you need that much hyperthreading, but again that my two cents. B4 you post what you plan on putting in your whip, give a little background, what do you plan on using this for etc.. etc..
    why would you even try to put the OS on a flash drive? not trying to flame but seriously.\
    Dec 2007
    Iowa
    Good point i should give a little background. Basically i'll be using it for anything i can think of at the time but mostly i want to be able to run SD, watch movies (anime), watch tv, use my phone and i thats about all i can think of now. You know how when you want to do something on your comp and find out its underpowered and everything runs slowly I HATE THAT it happens at work all the time so i want to be prepared for that. I have thought about using less RAM because i might want to use hibernate....... Still up in the air i'm going to run it with a 1 gig stick i have laying around and see how that goes.
    Now for the CF drive. I want to put the OS on a CF because access time is much faster than a spinning harddrive. I also live in Iowa and we had a low of -38 degrees this winter and solid state drives are fully functional at low temps.
    I also have a couple of questions that i have run into. How many SATA drives does the M2-ATX 160W Intelligent DC-DC PSU support? I couldn't seem to find an answer to that one. Also has anyone used the JetWay J9F2-EXTRMEM MB? How bad is the post time?
    Updates:
    I just bought my processor and i took it down a notch i got a core 2 duo t5500 (1.83GHz) a great 80 bucks on ebay with a 3 month warranty.
    Dec 2007
    Iowa
    After viewing vladcarpc i decided to do something similar and do a little diagram. Thanks vladcarpc
    Dec 2007
    Iowa
    New Update!!!
    It looks like centrafuse has gestures now and SD has no support so it looks like i'm going centrafuse
    Newbie dark_avenger's Avatar
    May 2008
    Melbourne, Aus
    compact flash has much shorter access times. but slower transfer rates.
    this more than likly will give you slower boot times.
    if the hdd will work in the lower temps then just use that and make a image of the boot partition so if the drive does fail then u have easy recovery.
    Dec 2007
    Iowa
    I thought that for a while but since the harddrive takes time to begin to spin it would make the boot time longer. Understandably sata 2 is about 375MB/s and sata 1 is about 187 MB/s and the compact flash drive is 45MB/s but instantaneous. I think this would be much faster boot up. I am using a momentus harddrive which from what i understand has 128 MB of flash memory in the harddrive itself. We will see which is faster. I'm thinking its going to be the CF. Anyone else have an opinion on this cause cutting out the CF will save me like 100 bucks. My cost has inflated to 2800 from 1900 lol
    May 2008
    Melbourne, Aus
    the speed of the sata II cable is rated to 3Gb/s however i have never seen speeds over 100Mb/s out of a desktop sata drive. at least the 7200RPM drives anyway.
    as for the spin up time of the drive. the drive will be spinning at full RPM before the bios finishes POST. only advantage of CF is the seek time. its in the nanoseconds instead of milliseconds.
  1. 2006 Tacoma Carputer
    By rac3pm in forum Show off your project
    Last Post: 04-21-2009, 01:54 AM
  2. Carputer build. Need help
    By dizbo66 in forum Newbie
    Last Post: 05-27-2008, 12:51 AM
  3. Replies: 5
    Last Post: 05-31-2007, 05:46 PM
  4. Carputer build, setup and design
    By stalkerstyle in forum Newbie
    Last Post: 02-02-2007, 11:27 PM
  5. How to build your carputer at a liquor store
    By C4M in forum General Hardware Discussion
    Last Post: 09-14-2002, 03:45 AM
