Hey all, using an Xbox as a media center for my car. Installed with few problems, but have a grounding issue (or so I would suppose). To start, yes, I've read the relevant newbie grounding stickies but they haven't solved my problems.
Only the right channel of my audio is buzzing. I've attempted to re seat the connections to no avail. If I unplug my
video connector from my
head unit, the buzzing becomes unbearably loud on the right side and becomes present on the left side.
I have as many electronics in my car grounded to a similar point, so no problem there. I've introduced a ground loop isolator for my audio channels, but that didn't help either. I then tried opening the Xbox and wired up a separate ground from the Xbox to the common grounding point I've explained above, but still no luck.
Surely someone has had a similar issue installing an Xbox? Any help is appreciated. The car is a 2005 Scion xB, if anyone needs that information, and the
power for my inverter comes from the accessory switch on my car.
