Results 1 to 4 of 4
Thread: Line-level sound card output to amplifier
    Nov 2006
    Hey everyone
    I read the thread on how to connect your computer's audio to your exisitng HU/amp, but I didn't see this issue addressed:
    Is the output from the sound card "line-level/pre-amp"? I.e. do I need to use a speaker-level -> line-level converter before running the sound card output to my amp's input? I have a feeling that it is not a low-line level output, but I didn't see that issue addressed in that thread.
    Thanks for the info!
    Variable Bitrate rgarjr's Avatar
    Jan 2008
    Covina, CA
    the audio off a pc's sound card is low level. So you simply just run a 3.5mm to dual RCA type adapter, then run regular RCA type patch cables to your audio amp.
    My carpc worklog
    Nov 2006
    Quote Originally Posted by rgarjr View Post
    Perfect, thank you. for some reason, I was thinking that it wasn't a low level output, but then again, computer speakers generally have a separate amp.
    Any idea what the voltage is coming out of the sound card? I don't know if the even spec that kind of thing... I guess I'll have to check w/ the mobo documentation...
    Maximum Bitrate FusionFanatic's Avatar
    May 2007
    Boston
    Quote Originally Posted by Rocket3004 View Post
    the output voltage is probably different for each mobo/soundcard. you can measure it with a multimeter set to AC volts.
    the output will vary depending on volume and tone level. you'll need to use a test-tone to give a constant output, then with volume up all the way; measure either channel's positive to ground (audio ground, not chassis ground).
    NOTE: this will be much easier to do from the RCA adapter outputs.
  1. bluetooth woes
    By gentoocar in forum Linux
    Last Post: 12-12-2009, 04:05 PM
  2. USB sound card output level
    By amemo06 in forum Car Audio
    Last Post: 01-03-2008, 04:07 PM
  3. Headphone vs line level outputs from computer, etc.
    By timeshifter in forum Car Audio
    Last Post: 12-31-2006, 01:21 PM
  4. Sound Card discussion, 4.1, sound quality, need help
    By jedi7001 in forum General Hardware Discussion
    Last Post: 05-19-2005, 10:47 AM
  5. Sound card reccomendation for **music**
    By TWBarrett in forum Car Audio
    Last Post: 09-09-2004, 10:40 PM
