So I jumped right in and bought an MSI GM965 motherboard and 2x 1GB compatable low prfofile RAM.
After my research yesterday heres the plan:
VoomPC Case
M2-ATX PSU
Intel T7700 Processor
250GB 2.5" SATA Hard Drive
Any issues?
Whats going on you guys. I decided about an hour ago that a carputer was the way to go so here I am. I am on a quest to build the ultimate A32 Maxima. I have been to this site a couple times through links from other forums, but know 0 about carputers. Time to do some research...
VoomPC Case
M2-ATX PSU
Any issues?
2GB of RAM seems a bit excessive, especially if you intend to use hibernate.
excessive is ok as long as its not a problem. like i said i dont know a whole bunch about computers, so what exactly is the issue?
Well if you are using hibernation, the more memory you have, the longer t takes for it to load all the memory from disk when you resume.
ok... i read that it would take longer to boot, so same type of thing. i dont really think hybernation should be an issue. because of some of the functions i plan on running i would imagine that hiberntation would be undesirable. i'll do some research, but is there any instance when a computer needs to hibernate?
Hibernation is only really used to speed up starting car to music playing times.
If you are not planning on isung hibernation then the larger memory is not an issue, just turn off the memory checking in BIOS
ok. i know what you're talking about now. i will not be hibernating.
I have a question.... Why is it people have issues with more RAM and hibernation. My system takes about 6 seconds to hibernate and maybe 4 to 5 seconds to start back up. Thats not long at all.... What is diffrent with your setups that it does take long.
Im running a KINO-690S1 with AMB Turion X2 processor and 2 gigs of RAM. The hibernation shouldnt really matter since your getting out your car anyways. Waking up though, I can live with 5 seconds.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
