If anyone cares, I believe i found the answer here:
PCI bus Max?
I'm trying to organize my car pc parts and came across this in my motherboard user manual. Not sure what this means, but im assuming it means that if i were to add a riser card i could have 2 pci slots from the one slot. Is this assumption correct?
PCI bus Max?
Yes they do make 2 slot risers. Only thing is is that if you have a standard 2 pci riser, it will act very bad if the cards are both highbandwith. The 2 cards will literally fight for bandwith.
You can buy a 2 slot PCI riser made for high bandwith items, but when I bought mine, it was difficult to setup.... could have just been me.... Logicsupply sells both types of riser.
HiJackZX1 w/ The Tobiathin Core PC system!
ZOTAC GF9300-G-E
INTEL E8200
4 Gigs
OCZ Vertex 2 SSD
OPUS 320
1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
Starting Raspberry Pi multizone project.
How do you find out if you cards are high bandwidth
Video and Sound are usually your main choices for PCI cards. Both would probably fall into that catagory. USB card would be another and it, too, would probably fall into high bandwidth catagory depending on how many devices it's controlling. Truth is, you probably just want to stay away from dual.
Edit: From looking at that other thread, they say you're fine, so you are probably fine running dual. Nice. At logic systems, they mention Via with their dual riser.
My opinion is my own.
