Results 1 to 8 of 8
Thread: Partition for windows
    Aug 2007
    So i got my carpc to work...kinda i have everything connected and i went to install windows and when i got to the partition part of it, it said i didnt have one so i went to create it by pressing c and entered the amount that i needed and pressed enter to create and nothing happened it just took me back to the screen that said i didnt have a partition and press c to create one.
    Who am I? HiJackZX1's Avatar
    Jul 2007
    Miami
    Quote Originally Posted by ChrisQ0904 View Post
    How big is the HDD? I have a 40 GB HDD, which is small if you take into account all the software, etc. I went with a 40 to avoid having to partition. All music and video will go on a seperate drive so I can take it in and out of the car. Are you planing on using 2 OSes?
    HiJackZX1 w/ The Tobiathin Core PC system!
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    1 Lilliput, 1 MTSVO-SC K301, 4 VM70 screens, 1 Eonon 19in
    Starting Raspberry Pi multizone project.
    Aug 2007
    the hdd is 120gb. and what is a oses? if its operating services then no i only plan to run xp
    Jul 2007
    Miami
    My bad, I meant Operating Systems. Wht not buy a 40GB HDD and use that for OS then use the 120 for strickly media.... Im not sure how others do it, maybe some1 else can chime in?
    ZOTAC GF9300-G-E
    INTEL E8200
    4 Gigs
    OCZ Vertex 2 SSD
    OPUS 320
    Newbie redcell3's Avatar
    May 2008
    nunya
    are you using the windows boot disc? is the bios set to boot from the cd? I'm pretty sure this isn't really an issue anymore, but if you are trying to partition the drive to fat16 it only allows up to 2gb per partition. Could you write down step by step what you are doing when you start the computer that way it is easier to diagnose the problem. computers can be finicky sometimes
    Mar 2007
    Barbados
    Two quick questions.
    1 Are you using a slimline cd\dvd drive?
    2 Do you have the hard drive and cd\dvd drive on the same ide cable?
    Aug 2007
    1) yes
    2) no
    Aug 2007
    Hey everyone just want to let you know i got it working now and just finished installing windows and now im going to setup everything else. thank you all for your help. Oh and i think it ended up being bad ram because i ended up buying a new one and it worked.
  1. Cloning a partition with Ghost
    By cMags in forum WinNT Based
    Last Post: 02-17-2007, 11:27 AM
  2. Upgrading Drive Used Arconis shows only old partition
    By bosstone74 in forum General Hardware Discussion
    Last Post: 06-11-2006, 09:47 PM
  3. Media library on 2nd partition
    By debugger in forum StreetDeck
    Last Post: 05-24-2006, 03:01 AM
  4. Replies: 9
    Last Post: 11-21-2005, 07:53 AM
  5. repartitioning HD for Mediacar possible?
    By fly_dutchie in forum General MP3Car Discussion
    Last Post: 05-21-2004, 11:31 AM
