Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: In-dash LCD + PC + multiple cameras
  1. #11
    Newbie AnimeCommander's Avatar
    May 2008
    Quote Originally Posted by cockie55 View Post
    The easiest way to switch automatically to the reverse camera input is to wire camera power using your reversing light circuit. Put gear shift in reverse, reverse lights go on which turns camera on.
    You can also power camera using say a dash mount switch (handy if you can't use rear mirrors in forward motion) but as this switch will also power up on your reversing light you need to instal a diode (which only allows current to flow one way) on the camera/switch side of the reverse lights to block power going to lights.
    If another input is in use, I do not think this will automatically switch it to the reverse camera's input. You could adapt this to wiring the switch button to a reverse-only power source (using a constant to momentary relay rig for more options). The problem being getting it back to whatever source you want when you put it back into drive - solvable by putting in a double pulse on the same button.
    I won't be installing a rear view camera. I don't understand the 'need' for one and will be using the secondary inputs for aux inputs for other devices.
  2. #12
    Mar 2008
    AnimeCommander,
    Thanks for the ideas you shared with me. I can see that, if one input is already being used for something other than the rear-view camera, it would be tricker to ensure that the display goes back to the 1st input after the rear-view camera is switched off.
    Thanks again!
  3. #13
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    i went the less travelled road.. went on ebay and bought a couple small use video capture devices. Allows you to display the camera feed from within ur skin and soon with the help of the fusion brain i'll be able to pan and tilt my front camera. from RRFusion.
    Live mp3Car Facebook Chat
  4. #14
    Mar 2008
    Sonicxtacy02, Would you mind elaborating on RRFusion for me?
  5. #15
    Woodbridge, VA
    Blog Entries
    55
    its a plugin i've made that allows you to control your fusion brain digital ouputs from within the Road Runner front-end software.
  6. #16
    May 2008
    Cape Town, SOUTH AFRICA
    Quote Originally Posted by FusionFanatic View Post
    Most small carPC monitors have a VGA computer input as well as 1 or 2 composite (RCA) video inputs. there will be a button on the front panel to select with video input source will be displayed.
    I use a Lilliput EBY-701; it has 1 VGA input and 2 composite video inputs. since the MP3car transflective monitor is an upgraded Lilliput 629 I would imagine that it has the same 3 inputs.
    regarding the camera, you can buy cameras in both regular and reverse (mirror) view. most cameras that are designed as backup camera will automatically reverse the image so that it will be displayed as a mirror view with any monitor.
    Hi.
    I have the exact same problem of connecting my reverse camera to my PC. I have a double-din Lilliput EBY-701 transflective upgrade monitor. Problem is - buttons for switching from PC to AV1/2 mode are hidden behind the dash. Hence my monitor is always on Pc mode, I'd have to dismount it from the dash each time I reversed in order to press the AV1 button. Is there a way of connecting the RCA cable from the camera directly on the PC? My Pc box has S-vidoe, which I assume is OUT. It also has COMP out.
  1. FAQ: LCD Technologies
    By dontpntpool in forum LCD/Display
    Last Post: 03-15-2007, 01:20 AM
