Results 1 to 5 of 5
Thread: seek advice for lv-671
    May 2008
    Hi,
    carputer noob here so bear with me. I have a lv-671 board with a 1g PentiumM/1G ram/80 gig laptop drive. I am wondering what power supply will power it sufficiently.
    I was looking at the M2-ATX but from another thread I see that it is not correct so I am wondering if the DSX12VD is more what I need?
    Will this regulator plug directly to the board or is some other intermediary device needed?
    Thanks in advance...
    Maximum Bitrate galvitron's Avatar
    Mar 2007
    Socal
    The DSX12VD will be perfect. I just bought one for my Commell LS-372 which has the 4-pin P4 style power connector like yours. I used to have the M2 but the DSX12VD is much better suited. If you use the M2 you will have to jury-rig a relay in somehow that triggers the M2 to simulate shutdown. The problem is that these boards don't have the 20-pin ATX connector to tell the power supply when they are done shutting down.
    2006 Lancer Evolution IX MR In-Dash PC Project - WIP
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    Installation/Fab/Assembly (Revised v2):
    [----------] 90%
    May 2008
    Thanks, galvitron,
    I am just trying to not make to many investment mistakes in getting this thing going, and being new to this I am sure I would make a few without asking a few seemingly stupid questions.
    I ordered my touchscreen yesterday so I am getting anxious about getting started.
    Thanks again,
    Mar 2007
    Socal
    No prob.
    Planning:
    [----------] 100%
    Purchasing:
    [----------] 90%
    [----------] 90%
    May 2008
    How about just a good regulator on the car's powersupply itself?
    You can run the LV671 on a car's 12V. Just use a good filter, 7812 regulator(s) and condensators to keep the spikes out. Of course, a 12V standard regulated vanilla car-laptop supply would do handily, then you connect the 19V output to the 4pin ATX connector of the LV-671.
  1. Small Car, budget complete setup advice
    By Scouse Monkey in forum Car Audio
    Last Post: 07-14-2010, 12:17 AM
  2. Replies: 0
    Last Post: 05-11-2007, 11:59 AM
  3. HQCT seek down problem
    By DrLove in forum Road Runner
    Last Post: 12-29-2006, 05:14 AM
  4. need advice on system type - ITX or ATX
    By craigj in forum Newbie
    Last Post: 09-18-2005, 11:03 PM
  5. Advice Needed
    By EBFoxbat in forum Car Audio
    Last Post: 11-22-2004, 10:05 AM
