Results 1 to 2 of 2
Thread: n00b here - Starting a carputer project for my WRX
    Newbie xrebel21's Avatar
    Jun 2008
    Hello all!
    As the title says, I'm going to start my first car pc project for my 07 subaru wrx. A little background info first. Right now I have a decent audio setup with an Infinity 6 channel amp powering polk 5.25 components in the front, polk 4" speakers in the rear and a 10" sub, all running out of an alpine hu with an alpine sirius tuner. I am pretty good with 12v systems, and did all the install work on my system myself. I'm also somewhat experienced with building pcs.
    Having all that said, I'm looking to build a car pc for the primary purposes of navigation, engine tuning/logging, and maybe bluetooth. I'm planning on keeping my current audio setup and using the aux-in on my hu.
    Right now I'm trying to figure out what type of computing power i'll need. My laptop (1.86 Ghz pentium m, 1GB ram) runs my ECU tuning software pretty slow, so I think I might go with 2 gigs ram and either a pentium m or a core 2 duo. I'm worried about using one of the VIA C7 or Celeron M setups because stability is a big concern for me.
    I know, a lot more research is needed.
    What do you all think?
    plan [oo--------]
    build [----------]
    install [----------]
    May 2008
    I'm doing the same for my STI. For the screen you can either check out the one from mechatronix or there is another from bybyte for cheaper. For the screen itself, the 2008 lilliput 629 seems to be the best bet since it fits both mounts and is cheap/bright.
    About the motherboard/cpu, you won't have any stability issues with the embeded processsers. You just have to decide exactly what you want to do with the computer, then decide if that cpu can handle it. Most people run those for everything from DVD's to music to Nav and it runs fine. I'm a computer nut so I'm of course going to get a Core Duo pulled from a new laptop for like 30$. The core duo mini-itx boards are 200+$ right now though.
    Lastly, start looking at front ends. Once you figure out what you want the computer to do, go make sure you can run everything on the front end you want. Most people choose RoadRunner, which is what I'm going with. The problem is, some software won't be skinable so it won't easily embed/run in roadrunner. I'm assuming this is the case of the tuning software you are running. If you check out the SUbaru skin one of the guys is working on, he found some software that I believe reads from a Tatrix cable and can monitor/log your car stats, but no tuning. That is what I plan to run so I don't have to spend 1k on Defi gauges. I'll just get my Utec protuned and leave that stuff to the pro's Good luck, just keep reading/searching. I have only been on here for a month or 2 just reading and have learned a lot.
  1. Replies: 14
    Last Post: 12-04-2007, 04:19 PM
  2. *WORKLOG* 98 Maxima, 8'' Carputer Screen Project
    By Nexson in forum Fabrication
    Last Post: 10-20-2007, 07:06 PM
  3. WTT: Carputer Project for In-Dash DVD PLayer
    By Guam_Guy in forum Classified Archive
    Last Post: 07-25-2005, 04:55 PM
  4. Carputer | n00b | 91' Subaru Legacy RS
    By bones in forum Newbie
    Last Post: 07-10-2005, 11:09 PM
  5. help - starting up carputer
    By tilezzzzz in forum Power Supplies
    Last Post: 06-18-2003, 01:52 PM
