Page 1 of 3 123 LastLast
Results 1 to 10 of 29
Thread: HELP! starting up for the first time. nothing happening.
    May 2008
    so i got most of my stuff... hooked everything up according to manuals and powered up. the cpu fan is spinning. monitor is no input. this is my first computer build so i'm not sure what i'm supposed to do now. according to the manual it should be showing post (whatever that looks like).
    msi fuzzy gm965
    intell t8100
    let me know if theres something else youd like to know to help me. thanks guys.
    Raw Wave lostreception's Avatar
    NY
    any beeps from the board
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    [(o)______(o)]b VanPimpin'
    LostReceptions Apps D/L Here
    GPSGasoline- Rewriting
    CarPCNetwork
    May 2008
    no sir.
    i should also add that the power led is not coming on, but i'm not 100% on that since i had to switch it up to match the connections on the board. the power button does work and the cpu fan spins but thats it.
    do i need to install bios or drivers first? i did not get the cd since i bought an open box but i can dl from msi.
    NY
    try removing the cmos battery (little watch battery for a minute or two) then replacing if that doesnt work try running only the PSU, mobo, CPU+heatsink+fan, internal speaker and see if you get a beep
    .______
    | '_ |__\___
    [(o)|___(o)] XB
    ._________
    | I__I I_I|_\__I
    CarPCNetwork
    May 2008
    i removed the battery and it didnt make a difference. there is also a jumper setting to clear cmos. do you think i should do that until i get it figured out?
    couple other things: p32 keyboard is flashing when i turn it on... usb optical drive mmakes a little noise.
    i will try taking off everything but the motherboard/cpu, ps, moitor, and keyboard. i have read something about ram compatability causing issues as well. do you think i should remove it?
    Low Bitrate TheSovereign's Avatar
    Feb 2008
    Nu Yawwwk
    If you remove the ram, you should get some beeping...
    May 2008
    well i stripped it all the way down to motherboard/cpu/psu and still no beeps.
    Variable Bitrate tigergibb's Avatar
    Nov 2006
    Snellville, GA
    possibly a doa(dead on arrival) motherboard. ask for a replacement?
    post(power on self test) should at least come on to tell you what's wrong.
    2003 Nissan Xterra Worklog
    Total amount spent so far: $1196.64
    You will probably spend AT LEAST 2x what you initially budget for your CarPC Project!
    2003 Nissan Xterra - Modifications
    May 2008
    ugggh. i really hope not becaue it was a final sale item. i'm assuming that means i'm screwed if it doesn't work.
    May 2008
    anybody else?
  1. Replies: 27
    Last Post: 03-04-2008, 03:46 PM
  2. Indexing music in 1.0.9.8 Failed
    Last Post: 07-07-2007, 12:19 PM
  3. Longest time between joining mp3car and actually starting project?
    By dodgetimes2 in forum General MP3Car Discussion
    Last Post: 06-14-2005, 08:18 PM
  4. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
